Issue with shapechanger
Category: Helpdesk · Tags: shapechanger · Posts: 8
#1 — dni_br · 2019-03-03
Hello,
I just received my shapechanger. I dont know if i m doing something wrong with it or if i have an issue with it.
Using navigator shapechanger combo i m not able to create a shape and play with as i should do.
So to check the SC i ve pluged directly the H and V ramp from VC. Here the result :
Here the SC setup
Here the VC setup
if someone can help me…thx
denis
#4 — dni_br · 2019-03-04
Thank you.
I ve tried. always the same result a screen splited with a white side and a black side.
No shape…
#6 — dni_br · 2019-03-04
yes of course !
only the navigator. shapechanger doesn t have rca sync
#7 — luix · 2019-03-04
you will need to play with the mirrors to get it working and do 2d quadrilateral shapes, it will take you time to understand all the options shapechanger has.
#8 — luix · 2019-03-04
Try this patch, check all switches are the same
#9 — Jesse · 2019-03-05
Does the shape show correctly with ramps plugged into shapechanger only?
#10 — dni_br · 2019-03-06
Hey tanks. you re right, need time to understand the beast. mirror switches solved all my questions.
thanx
#11 — creatorlars · 2019-03-09
Yep, both mirror switches up! The user reference card contains the “home position” in an illustration in case you get stuck.
