Akai MPC 2000XL SMPTE
#1 — edward72 · 2019-03-04
wondering if there is a way/use to interface/sync MPC SMPTE with Expedition?
cheers!
PS out of interest, is there a user reference card out there for Bridge or u.r.c./manual for Passage?
#3 — edward72 · 2019-03-04
thanks. i did find these but i think bridge is corrupted? i guess passage doesn’t really need one.
mapper too & shapechanger owners manual.pdf perhaps?
SMPTE - no use I assume?
I wonder why they included that feature. i was hoping i could sync the drum machine to lzx or timecode somehow by SMPTE. Edirol mixer has Midi tho so maybe i can go that way. just interested about the possibility. a lot to learn from scratch. thx
#4 — scolopendra · 2019-03-05
It could be fun to experiment with SMPTE if you wanted to play a long chunk of existing footage into the system from something like a computer, Andor-1, or Edirol P-10. Replace the audio track with SMPTE code, and the MPC should follow along perfectly…
#5 — scolopendra · 2019-03-05
If you want to use the original audio from the footage, then move it over to the MPC before replacing it with SMPTE - then just play it back like any other sample.
You could also send MIDI commands to your Edirol mixer from the MPC- then everything would be in sync, and you could automate some eye-poppingly tight rhythmic edits…
