Cadet and other modules
#1 — o2w · 2019-07-11
hi, so I finished building the Cadet modules
:star_struck:
(super excited) and am now thinking of the next module :slight_smile:
but am not sure what would be the best fit. Any recommendations? I am hoping to get to something at the level of the vidiot but can’t afford that and prefer DIY :slight_smile:
#2 — JunkRhythm · 2019-07-11
More Cadet Processors, Multipliers, Faders or Hard Keys will really open up your possibilities. More Cadet VCOs won’t hurt either but my money is on the first three mentioned.
#3 — Agawell · 2019-07-11
have you built one of each or the cadet 21 system? - there are multiples of various modules to better handle rgb
this may give you some ideas
otherwise take a look at the castle modules - which are very interesting - again multiples work well - 3ADC and 2DAC + other modules if you wan to process all rgb signals
another possibility is non-video eurorack modules (inc diy) for example - I regularly use a doepfer distortion/waveshaper to add a little something to my video signals - Make Noise Maths and Mutable Instruments Stages for modulation - I’ve even run video signals through MI Clouds before now
generally the analogue modules are more likely to work with video rate signals
#4 — reverselandfill · 2019-07-11
Look at the Castle and Sandin projects. Also, there are some other designs out there.
see here: https://drive.google.com/drive/folders/0B_gD4TorwvAdN2dGNzdvUENETVk
#5 — wednesdayayay · 2019-07-14
the triple function generator project on this forum is about to happen that seems like a good place to go next!
#6 — Marizu · 2019-07-15
I spent a couple of years trying to figure this lot out before I dived in. It became clear that Visual Cortex (and I assume) Vidiot contain more functionality than you could DIY for the price. They also do it in a way that is very well balanced and considered.
I didn’t really understand how powerful the Cortex was until I got it. I have massively augmented it with Cadets, Castles, a Staircase and Bridge.
Obviously, this all depends on the direction that you want to take your creativity in.
