All About Pendulum
Category: Legacy Docs · Tags: eurorack, expedition, pendulum · Posts: 1
#1 — Z0NK0UT · 2019-07-16
Pendulum%20Front%20Photo%20550px
Pendulum%20Side%20Photo%20550px
Behold Pendulum, an undulating maelstrom of analogue motion for your video synthesis patches. More than a dual oscillator, Pendulum delivers maximum utility with her signal crossfader and router. Fantastic as both a control voltage source and modulation effect.
Specifications
Pendulum_Product_Icon_280dpi_small
User Reference
PendulumUserReference
Videos
Patching Tips
Pendulum’s crossfader can operate in several modes, depending on how it’s patched.
Voltage Controlled Amplifier (VCA)
Patch your source to A In. Take your output from D Out. The Cross control and VC input will now control the gain of your input signal.
2-Input Crossfader
Patch your sources to A In and B In. Take your output from D Out. The Cross control will now control a crossfade between the signals at the A and B inputs.
1-Input, 2-Output Router/Panner
Patch your sources to A In. Take your outputs from C Out and D Out. The Cross control will now move the signal from the C Output to the D Output as it is adjusted
2-Input, 2-Output Double Fader
This one works great when processing H and V ramp signals to perform 90 degree rotation. Patch your sources to A In and B In. Take your outputs from C Out and D Out. The Cross control will now fade between the A and B inputs in opposite directions on each output.
Downloads
Production
Other Resources
