All About Staircase
Category: Legacy Docs · Tags: eurorack, expedition, staircase · Posts: 1
#1 — Z0NK0UT · 2019-07-22
staircase1
Staircase is the result of a few years of thought put into the subject of abstract pattern generation using analog computing techniques. It is a component of several modules designed for the purpose of processing horizontal and vertical ramp waveforms as the core source of
a complex 2D figure or pattern. Staircase can be used in much the same way as a synced horizontal or vertical oscillator when fed a horizontal or vertical ramp as its source, but its applications are much more open ended.
In video synthesis patches using our first generation of modules, it was often difficult to break away from the restriction of horizontal and vertical elements and motions. This was largely due to VCOs being the primary pattern generation source, and VCOs being able to lock to either horizontal or vertical directions only. To generate a 2D pattern, a vertically locked oscillator would modulate a horizontally locked oscillator. Staircase breaks out of this paradigm entirely, since its frequency modulation function is achieved through nonlinear waveshaping. This makes it possible to multiply the frequency of a 2D plane rather than a unidimensional one. By this methodology, one pattern can create another, in endless configurations. This method of using chained full wave rectifiers as frequency doublers was first used by us in the original Video Waveform Generator module, to double the frequency of the triangle oscillator core and enable the generation of a sawtooth/ramp waveshape output. It was used again in the polar-to-cartesian waveshaping portion of the Mapper module. Doorway expands on the concept and grants access to its inner workings in a creatively potent manner.
Staircase is a wideband analog frequency multiplier for video processing and pattern generation. It allows the video synthesist to instantly add greater visual complexity to their patches. It can split an elliptical gradient into a series of concentric rings, solarize an input camera source until the brightness of the signal has wrapped around many times, or perform the simple functions of a VCA, mixer, and sawtooth-to-triangle waveshaper.
Specifications
User Reference
stair%20urc
Videos
Patching Tips
Downloads
Other Resources
