Sync cables jammed up Cadet modules
Category: Helpdesk · Tags: cable, cadet, sync, vidiot · Posts: 3
#1 — tnohe · 2019-07-26
I’ve found that when I tried to use the LZX Video Synch distribution cable with my Cadet modules side by side in the case that I don’t have enough space. Currently I need at least 1-2 hp between each Cadet or Castle to keep from overcrowding.
I’m building one of Martijn’s (Reverselandfill) buffered sync busboards as a way to get around the crowding. To get this working all I would need then is a master synch from Cortex to the busboard, and then individual 2.54mm Pitch 14 Pin Female to Female IDC cables to each module?
#2 — reverselandfill · 2019-07-27
jep!
14pin sync from VC to the busboard sync input.
16 to 16pin power cable from your power busboard to the sync busboard
and then you have 10 x 14pin buffered sync connectors for connecting your modules.
#3 — creatorlars · 2019-07-29
You can cut off/remove the strain reliefs on the sync distro cable to get it to fit between Cadets.
