H2CS HDMI to Component Video Converter prevents Intensity Shuttle from capturing
Category: Helpdesk · Tags: capture, converter, externalvideo, visualcortex · Posts: 4
#1 — sambell001 · 2019-10-18
Hello
I can get the Black Magic Intensity Shuttle to capture from the Visual Cortex through the Black Magic Media Express desktop app on my mac mini. Which is great!
:grinning:
I can also get an image into the Visual Cortex, from my macbook pro, through the H2CS ‘Universal HDMI to Component Video Converter’. Which is also great!
:grinning:
Problem is, I can’t get them to work together.
:sob:
I remember back before the rollout of this forum when there was a section on the lzx website which was like a ‘getting started’ explainer which described what one would need to delve into video synthesis.
I’m pretty sure the BM IS was on there as :the: video capture device, as was the H2CS as :the: hdmi to component converter. Am I missing something? Any work-arounds?
The VC is set to decoder on the little switch on the back.
S
i made a wee video and put it on youtube here
#2 — sambell001 · 2019-10-23
Solved… i think…
I picked up a £20 Component to HDMI converter. It drops frames every so often but seems to be working quite well apart from that.
:crossed_fingers:
:nerd_face:
#3 — creatorlars · 2019-10-29
Yeah, YMMV when it comes to cheaper devices interacting with each other. Consumer grade stuff is meant to convert formats for display on a TV as cheaply as possible. If you can afford it, go with broadcast quality converters from Blackmagic or AJA. They are designed for reliable capture/recording.
#4 — sambell001 · 2019-11-20
okie dokie
thanks for your reply Lars. much appreciated.
