Vidiot horizontal scrolling issue
Category: Helpdesk · Tags: — · Posts: 4
#1 — missliz · 2019-10-22
When I switch the loop button DOWN on the VIDIOT, the input image scrolls horizontally from left to right, even with both sync buttons down. When I switch the loop button UP, my input image disappears - how can I solve this issue? I have tried different powering up sequences, changing video cables, checking source image stability. No luck.
#2 — Z0NK0UT · 2019-10-23
Sorry to hear of your Vidiot troubles!
How long have you had your Vidiot and where did you get it?
Are you using a PAL or NTSC monitor?
What is your video source?
#3 — missliz · 2019-10-23
Dear Dave,
See Invoice attached below
I’ve had it for under 1 year.
I purchased the VIDIOT from LZX directly , January 18 2018 and received it 8 months later in October 2018, and immediately contacted LZX and the helpdesk about the problem.
To be honest I don’t think the source, nor the viewing method are the problem:
I’m using a projector, because that’s how the image is shown live at concerts. I have tried HDMI projectors, and analog projectors.
Video source is an ntsc mp4 file playing on my laptop with powered HDMI to RCA Converter; I’ve also tried a live ntsc go pro feed, and a live ntsc Canon camera feed with S-Video to RCA.
When I bypass the Vidiot in the chain, the image is clear and steady on the projector.
When I add the Vidiot to the chain
When I switch the loop button DOWN on the VIDIOT, the input image scrolls horizontally from left to right, even with both sync buttons downWhen I switch the loop button UP, my input image disappears. The effects (not the source image) are steady though in both Loop positions-
(Attachment LZX-VIDIOT-RECEIT-EW.pdf is missing)
#5 — Z0NK0UT · 2019-10-23
I see you have an open support ticket that I last replied to in March. I sent you another message, via email.
