Vidiot stuck in white screen
Category: Helpdesk · Tags: vidiot · Posts: 4
#1 — robotnik · 2019-11-07
hello,
we are stuck in white with an brand new vidiot device.
the first minutes after unpacking it reacted quite well also with camera input but after an couple of minutes we got stuck in an white screen. no mater what ever we do.
the center led indicator is always on.
very very rarely we get a picture by it self, the center led indicator turns of. but this state wont last long.
we tried to repatch this example https://www.youtube.com/watch?time_continue=6&v=Lngn4w46EdA without successes.
we haven’t attached any external device yet. except one camera to the dedicated cinch input.
we tried the included patch-cables with the device itself considering input/output directions.
so we come to the conclusion something must be wrong ? maybe a bad contact in the normalization chain or a bad solder joint ?
thanks for any help in advance !
#2 — Z0NK0UT · 2019-11-07
Sorry to hear of your Vidiot troubles!
Where are you located? What sort of monitor are you using? Have you tried switching between NTSC and PAL formats?
#3 — robotnik · 2019-11-08
thank you for your reply.
it’s an old professional sony video monitor with composite input.
yes. we tried ntsc and pal.
its erratic behavior (suddenly showing an picture and suddenly falling back to white) feels like an loose connection.
we are located in germany.
#4 — Z0NK0UT · 2019-11-12
Thanks for the info. It seems best to open a support ticket. Could you send an email via the LZX website?
