Escher sketch sync?
Category: Helpdesk · Tags: — · Posts: 4
#1 — dni_br · 2019-12-16
Hello. How do you know that Escher Sketch is synced ? Wich one of the two RCA is the sync input ?
thx
#2 — Z0NK0UT · 2019-12-17
You can use either jack, as described in the user reference card.
https://github.com/lzxindustries/documentation/tree/master/Escher%20SketchLZX Industries Product Documentation. Contribute to lzxindustries/documentation development by creating an account on GitHub.
Link: lzxindustries/documentation
#3 — dni_br · 2019-12-17
Yes, thanks.
But whats the special behavior of ES when sync, because i see no difference with the rca pluged in or not.
#4 — Z0NK0UT · 2019-12-17
Further explained here:
What’s the sync connection do for the Escher Sketch? User card says “Escher Sketch uses video sync to synchronize its outputs to the refresh rate of your video synthesis system” but what’s that actually mean to users? Does that mean the output is time-quantized to the framerate (or maybe line rate)? And if so, why is that more desirable than an unquantized output (which I presume would be higher time resolution)? Does it matter more to the Orion modules (presumably since they’re digital) than to…>
