Insert frame into framebuffer
Category: Unknown · Tags: memorypalace · Posts: 2
#1 — cburst · 2019-12-28
Hi there-
I was just watching the Jones framebuffer DVD from the ETC ‘Early video instruments’ set. One interesting feature is the ability to add a single image into a specific frame of the frame buffer (i.e., frame 12/30, repeating once each second). I’m going to start trying the new memory palace firmware beta today, but I was wondering if the ability to insert a frame into the framebuffer is a possible future firmware feature.
#2 — Z0NK0UT · 2019-12-28
Moved your comment here:
As promised, we have a new version of Memory Palace firmware for you all to try.  At this time, there are some rough edges and still a lot of work to do.  We plan to have V19 wrapped up at the same time TBC2 ships, since they will share a common code base.  If you’re happy with the current firmware and don’t want to disturb any projects or performances in progress, you should stick with V18 until we get to that point. > BUT! If you’re anxious for some really powerful new features and performance …>
