Composite signal adjusting and manipulating
#1 — SPIKE · 2020-01-09
i recently acquired a conversion box for my Gieskes Oscillatascope2B which is a VGA output:
amazon.com
https://www.amazon.com/gp/product/B07L6WHQ6H/ref=ppx_yo_dt_b_asin_title_o04_s02?ie=UTF8&psc=1&pldnSite=1Buy eKL VGA to AV Adapter Converter Box VGA Input Composite RCA S-Video VGA Output Computer PC Laptop to TV Display Projector Connector: Video Converters - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
** $25.99 Link:** Amazon.com: eKL VGA to AV Adapter Converter Box VGA Input Composite RCA S-Video...
this box let’s me adjust the size, shape and position of the composite output.
does anyone know of a box with similar features that would have these features for a composite signal?
i don’t mean for converting composite to anything else…i’m just looking for a way to be able adjust a composite output in the same way.
or…is my only option to xvert composite to VGA and then back out again?
thanks for any help!
#2 — transistorcat · 2020-01-09
The fact that the “frequently bought together” box lists a composite -> VGA adapter makes me suspect other people have resorted to that solution
#3 — bobster · 2020-01-11
Yes the giesix stuff leaves a lot to be desired. Why not just spring for a visual cortex before they go out of print?
#4 — SPIKE · 2020-01-11
well…i already have all the Gieskes stuff and no room left in my modular setup for another module.
:stuck_out_tongue:
the giant hole in my video noiz setup is awaiting a Memory Palace.
#5 — SPIKE · 2020-02-04
just an FYI on how this turned out.
i ended up getting this doodad:
amazon.com
https://www.amazon.com/gp/product/B076CF51NK/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1&pldnSite=1Amazon.com: Wiistar AV S-Video Composite to VGA Video Converter Box for DVD DVR VCR Monitor: Electronics
** $16.99 Link:** Amazon.com: Wiistar AV S-Video Composite to VGA Video Converter Box for DVD DVR...
so i converted the composite vid signal to VGA and then back to composite with first VGA adaptor i bought.
it took a little coaxing but once it was happy with the signal…it started working!
now i can adjust the position of the composite output from some other devices.
for instance the DU-NTSC is not centered on the screen.
now i can easily nudge it around the screen.
this is also true for the outputs of the Critter and Guitari vid scope thingies.
here’s the DU-NTSC from last night’s session of Late Night Noiz For Late Night Fiends…
(it appears a few mins in)
