What is the Vidiot shape knob doing?
Category: Helpdesk · Tags: vidiot · Posts: 7
#1 — vidioray · 2020-02-05
I searched on the form but can’t find a straightforward answer. What exactly is the Vidiot’s shape knob doing?
#2 — csboling · 2020-02-05
It controls a crossfader between the horizontal and vertical oscillators, using different oscillator outputs for the diamond (triangle outputs) or circle (sine outputs). If you patch the H and V triangle outputs from the Vidiot to a Cadet crossfader and sweep the knob, the result looks identical to sweeping the Vidiot shape knob and looking at the Vidiot diamond output.
#3 — Vdot · 2020-02-06
CV control over the shape knob seems like an odd omission on the Vidiot, it’s such a effective modifier.
#4 — vidioray · 2020-02-06
Totally. Wonder if there’s a way to mod it…
#5 — reverselandfill · 2020-02-06
the shape knob is a rotary switch (if I remember correctly) so CV control is more difficult probably
#6 — Vdot · 2020-02-06
The Cadet Fader module does it. If you have any interest in DIY I highly recommend the Cadets as a way to expand the Vidiot. The parts sourcing is not fun but once I had all the parts I had a great time assembling them and learned a whole lot about how the Vidiot and video synthesis works. It also made me appreciate how much value goes into the LZX modules.
#7 — Z0NK0UT · 2020-02-07
You could also use the fader in Bridge or Pendulum.
