Cadet video feedback
#1 — vidioray · 2020-06-17
Hi. How could a camera feedback patch be created using only Cadets? Is there a way to do it with brightness/contrast/details controls like the ones available on the Vidiot?
Thanks!
#2 — transistorcat · 2020-06-17
I’m not quite sure i understand the question?
All you need for feedback is a way to input and output video, optionally with some manipulation in-between.
If’ you’re looking for a simple starting point, routing from input -> [either a processor or a hard key] -> output is enough to get interesting results.
#3 — vidioray · 2020-06-17
I should’ve specified camera feedback. I’ve updated the post. Also what do you mean by output? There is no output cadet module I believe.
#4 — reverselandfill · 2020-06-17
yes there is. the RGB Encoder
I do mostly feedback with my Cadet and Castle modular.
these modules are a lot of fun:
- Castle DAC & ADC (I have 3 of each, for crazy and shifting highly controlled paint effects)
- Triple Sandin Function Generator (acts a a equalizer for color transformations)
- Differentiator (edges and feedback = repeating edges)
- Matrix Mixer (that’s why I made it)
Other techniques:
- interference lines / shapes that trigger the feedback (VCO or noise in combination with Key generators)
- you can do a vactrol mod on the Castle ADC, to sweep the bias. wonderful effect!
- external feedback is cool too, as stated above. patch in some glitchy effects in between
- the use of audio modules to create effects. works well in combination with a matrix mixer.
