Diver ramps not aligned properly
Category: Helpdesk · Tags: — · Posts: 6
#1 — vidioray · 2020-07-10
Hi. The X ramp on my diver is not aligned properly. There is a +1 seam on the 0 edge of the ramp and when it’s mirrored the whole thing is off center. Is there a way I can fix this or do I have to return it?
Thanks!
#2 — Z0NK0UT · 2020-07-10
Thanks for posting about Diver. We’re collecting Diver quirks and bugs in this thread:
I received a Diver in the latest (December 2019) batch which works well, but all ramp patterns show a “seam” running vertically at a constant position, about 3/4 of the way across the screen. It appears with any bank selected and its position is unchanged by any panel controls. It is most obvious for vertical ramps but also visible with H+V or H-V outputs if you’re looking for it. > I see the discontinuity when using Visual Cortex, Cadet II, or Memory Palace as output encoders, with multiple disp…>
#3 — vidioray · 2020-07-14
Thanks. So this is not a known bug? Is it possible that I received a defective unit?
#4 — Z0NK0UT · 2020-07-14
This is a known bug, as noted in the thread linked above.
#5 — Dr_Rek · 2020-07-17
Looking forward to fixes in upcoming firmware, Memory Palace has a centering issue that may get fixed too. That said, working with all the quirks and bugs until they are squashed will still get you amazing video art.
