Control Voltage in Tachyons+ Gear: Chromagnon, Korg SQ1 Step Sequencer, or MakeNoise Wogglebug?
Category: Unknown · Tags: chromagnon · Posts: 6
#1 — guerrillasuite · 2020-08-26
Hello!
I currently have a Tachyons+ Psycheniser, which has two CV inputs (-5V, +5V) which I would like to make use of.
Logan recommends the MakeNoise Wogglebug ($450AUD) for some wild, crazy signals to animate the gear’s glitch effects.
I saw someone used the Korg S10 step sequencer ($190AUD) with their Psycheniser and achieved what they wanted (I’m assuming a more uniform beat/pulse?).
Now I’m wondering, which of the two should I get? What is a step sequencer and how would it apply to this?
I have a Chromagnon on pre-order also, does that have any CV outputs?
Thanks heaps!
#2 — jwsmithwick1 · 2020-08-26
The Wogglebug outputs random voltages at a clocked rate, whereas the sequencer outputs user-defined voltages at a clocked rate.
I would recommend starting with the sequencer because it allows you to program voltage patterns that you can send to both audio and video synthesizers.
#3 — Z0NK0UT · 2020-08-26
The Korg SQ1 is nice because it can send out voltage scaled to an LZX-friendly 0-1V. Also, it’s standalone and battery powered. If you get a Wogglebug, you will have to get a Eurorack case to use it.
Chromagnon will have control voltage inputs and outputs to patch with SQ1 and your Tachyons gear.
#4 — guerrillasuite · 2020-08-28
Thanks for the reply!
On the Korg website, under the CV Out Voltage it says “1V, 2V, 5V (Oct) 8V (Hz/V)”
The T+ gear operates at a -5, +5 V range so I’m assuming this will be fine, but what does Oct mean in this context?
#5 — Agawell · 2020-08-28
Octave
1v/octave
2v/octave etc
8V(Hz/V) is for buchla synthesizers iirc
normal eurorack audio oscillators track at 1v/oct - each note is represented by a 1/12 of an octave offset from the octave do for example c3 might be 3V, c1 would be 1V, c4 would be 4V - d3 would be 3.1667V etc etc
you may only get +ve values out of sq1
#6 — Vdot · 2020-08-28
Whoa I just realized that I can sequence within the 1st octave of my sequencer to stay in 0-1v LZX range. Thanks,
