Mesh displacement on the memory palace
#1 — cburst · 2020-09-16
hi there-
i have a question about mesh displacement on the memory palace.
what kinds of waves/frequencies do the alpha and aux inputs respond to in a stable manner?
i have been trying to reproduce the patching in this tutorial: https://www.youtube.com/watch?v=mDPB47sZsio&t=203s
using the equipment i have on hand (audio input/VCO/LFO)
i have had a hard time producing stable x/y mesh displacement. most of the time the displacement is either far too rapid or far too slow to look meaningful.
from my efforts so far, it seems that the aux/y displacement seems to respond to VCO sine waves at certain frequencies. the alpha/x displacement is another matter. i have had some limited success with audio input.
really looking forward to hearing some suggestions here.
#3 — Z0NK0UT · 2020-09-16
Attenuation is a must. If you’re using audio modules, scaling down to 0-1V would also be helpful. If you have an oscillator synced to your LZX gear, you will get the best results.
#4 — cburst · 2020-09-22
thanks for the tips! turns out i wasn’t attenuating or syncing enough!
