Weird time to be a starting an LZX system
Category: Unknown · Tags: — · Posts: 30
#1 — Second_Breakfast · 2020-09-21
As a newbie who decided to jump into video synthesis in the last couple weeks, I wanted to share my thoughts on what’s been positive and negative so far.
I’ve had great conversations with individual members of the VS community that have helped me tremendously as I start to wrap my head around what I need to get started. I work in video professionally so while video concepts aren’t foreign to me, understanding how LZX has implemented them into modular format has still required some educating. I also have been making music with eurorack with 6 years. With both those backgrounds, it’s still been harder for me than I excepted to wrap my head around everything. I think the main issue is that while information is out there, it’s scattered and fragmented. Often I’ll watch an informative video about one module that I have pre-ordered. However, the video is a bit old and the demo is pairing that module with other modules which are now discontinued.
‘Discontinued’ is a good lead-in for the next part of my experience. As everyone knows there are very few LZX modules available to purchase as of Sept. 2020. Certainly no way to start a system. It’s all pre-order. That’s fine, I understand the predicament of a small operation, especially in 2020. However, it feels like if I hope to eventually have all the parts I want for my system I need to put preorders in now (which I have). However it still seems like certain key pieces that have been discontinued don’t have a replacement available to even preorder. So I’ve preordered a grip of stuff only to realize something I definitely need (the Marble Index or Visual Cortex) won’t be coming back and I don’t have any idea when a replacement will arrive. Even if I get all the other stuff slated for fall production, it’s unclear how long I’ll be waiting to actually tie those pieces together in the way I want given the gap in modules that have been discontinued without being replaced. I have read the post from last year about the road map to replace those modules. However, it seems like the timeline projected at that announcement isn’t valid anymore. Maybe just an update with a more realistic timeframe would help? I can see how this disconnect between discontinued modules and replacements wouldn’t be a big deal for people who already have a system built up but for us starting from scratch it’s a more difficult issue.
Anyways, I’m excited to be jumping into LZX video world but just felt like venting some of my current concerns having done so at the point in time.
#2 — Fabong · 2020-09-21
I feel your pain, I decided against starting a video system earlier this year for exactly these reasons. Starting to think twice about the endeavour altogether, perhaps I’ll just make a DIY system of some sort in the future based on Cadet/Castle designs.
#3 — Jefro · 2020-09-21
I’m probably stating the obvious here, but keep your eyes on eBay, reverb, etc. I’ve built a lot of my system with used modules. Join the LZX Facebook group as well, stuff gets listed there often before it hits eBay or reverb.
#4 — Z0NK0UT · 2020-09-21
Welcome to the weird and wonderful world of video synthesis. You’ve noted it in your post, but it must be restated with emphasis: COVID!
The entirety of LZX’s 2020 vision was concocted outside of the harsh realities of 2020. The pandemic started beating up the supply chain in January and continued to wreak havoc through summer. Suppliers are still catching up and LZX is still short staffed. Things would be very different were it not for the pandemic. So…it’s a weird time to be starting anything.
Chromagnon is the foundation of the future of analog video synthesis. That’s where we expect you to start. Arch, Bridge, Curtain, Doorway, Mapper, Passage, Pendulum, Staircase, and Sensory Translator will all be restocked before the next generation of Visionary modules is announced. The Orion series will be restocked after Chromagnon back orders have shipped. Progress is steady…but slow by necessity. The pandemic still exists and continues to exert pressure on the tiny operation that is LZX.
I hope you can hang in there through weird 2020. Great things are happening at LZX–just not at all like we expected.
#5 — Rik_bS · 2020-09-22
It’s probably worth noting that once you have a “core” set of modules - sync gen, input, ramps and output, there are a growing number of options coming on to the DIY market that will fill the gaps. If you are comfortable sourcing and assembling components to a Panel & PCB set, consider that option…
Your intended use will determine what modules to source, and maybe use this “pause period” to further your learning and refine the intended system purchasing.
#6 — joem · 2020-09-22
It’s already been mentioned, but it’s just bad timing with COVID, which hit LZX right in the middle of this transition period of modules. You can be sure that LZX wanted the transition to be smoother than this, but there’s only so many possible-delays you can factor in if you’re telling someone an estimated release date, and no one ever factors in the possibility that a global pandemic could happen.
#7 — phosphenes · 2020-09-22
I feel the same, I’ve just bought a case and PSU3! Could really do with another quick run of Cadet I sync boards in the mean time so at least there’s something available that generates a master sync signal. Would be great to get a sneak peak at the new DIY range Lars mentioned but I completely understand why COVID has slowed things down.
#9 — Z0NK0UT · 2020-09-23
There is someone offering built Cadet I’s:
warning>>>> 9/25/20 STOCK UPDATE > warning>>>> > VCOs are now sold out! might make more stock of some of the others that are in short supply available later this year but for many of these this is all that’s left. still have plenty of materials for sync cables and still shipping one free with any order of 5 cadets or more. also happy to make single 14-pin sync cables in any length up to 12" for $5 shipped with any Cadet purchase if you only need to connect one VCO, Ramp Generator or RGB Encoder to a sy…>
#10 — Genlok · 2020-09-23
While you’re waiting you could explore other facets of video art, if that interests you. For instance there’s quite a lot you can do with “obsolete” video equipment that’s readily available used, such as SD mixers, cameras, tube TVs, and processors. You can also explore the growing world of Raspberry Pi-based video software like r_e_c_u_r and waaaave_pool, which is easy and affordable to put together. There are also at least a couple digital video synthesis modules, Structure and Hypno are both worth checking out. All of the above will expand the capabilities of your LZX system when you do get it built.
#11 — nerdware · 2020-09-23
I agree with everyone here, but I particularly like Genlok’s suggestions. I think Structure should fit well with your existing eurorack modules and will work with your LZX system when that arrives.
You’ll need a monitor that can display your video, of course, but there are already threads on this forum covering that.
#12 — sean · 2020-09-23
If you have the financial means to buy a whole system at once, they do come up for sale with some regularity. I’d say, since I started paying attention a couple years ago, I’ve seen one posted somewhere or another once every 2–3 months.
Here’s one right now. (No idea if this person is willing to deal with non-local buyers.) (Edit: did hear from one person that they did not have a positive experience trying to work out a deal with this seller FWIW, but YMMV.)
More than scarcity per se, the problem I’ve seen is that used prices have been generally trending upward on the discontinued modules (at least on the easier sources like Ebay and Reverb) — though I did manage to snag a used Visual Cortex at a good price right at the beginning of the pandemic.
#13 — Second_Breakfast · 2020-09-23
Thank for the replies and suggestions. I have definitely been keeping at eye out at the aforementioned forums/groups/marketplaces for modules. Right now I’ve got most of what I’ll need preordered or in-route from a few shops that had a few utility modules in stock. At the point in time when I’ll have all the modules I’ve preordered racked (including Chromagnon being finished/delivered) it seems like what I’ll be missing is a way to mix/composite an external video source coming from Andor 1, a keyed image from Memory Palace, and a background layer from Fortress. To the best of my understanding, Marble Index would have been the perfect module for this task. So if anyone has one to part with or finds one in the wild let me know!
#14 — wednesdayayay · 2020-09-24
this can also be done with a video mixer.
never underestimate just how useful an external video mixer is if you have the space for it.
you don’t see many marble indexes pop up especially now since TBC2 is almost out…
the most important module in video synthesis is patience.
the most useful module is knowing what you are trying to make.
#15 — 337is · 2020-09-24
Boom! Full stop capital T Truth.
#16 — sean · 2020-09-24
Here’s another one of my “wouldn’t this be nice?” Photoshop renders:
RGB_Fader
(Again, not taking into account the panel space vs. PCB space issue… This would certainly need to be a couple/few stacked PCBs.)
Added in a scaling switch on the CV input, figuring it could pair nicely with something like a Wobla.
#17 — rempesm · 2020-09-24
I think @VisibleSignals is working on something like this:
On the subject of cross-fader modules: I will be offering a PCB/panel set for DIY builders soon, which provides three channel (RGB) cross-fader/keyer functionality between two sets of RGB inputs.  I’ll write more soon, but if you’re interested or have questions now then please feel free to PM me!>
#18 — sean · 2020-09-24
Ah, yes. I had seen that, but forgot about it (I tend to be so visual that, if I don’t see something like a full panel sketch, it doesn’t quite register with me; hence the renders).
Nice!
#19 — VisibleSignals · 2020-09-24
Here’s what my RGB Matrix modules look like (please ignore the red preliminary prototype design, the blues ones are what I’ll be offering). I’m sorry it isn’t announced properly yet, I’m just making some demo videos to show how it works and sorting out the final details to make them easier to assemble.
20200915_0832371
The Combo panel has two Input sections, an Output section and a Keyer section - I’ve since added text to the panel to indicate this.
#20 — rempesm · 2020-09-24
Very cool @VisibleSignals. Looking forward to seeing the demos and getting a better handle on the signal flow.
What is the idea behind having a destination switch for A/B? Does it let you sum the A/B channel inputs together into a single RGB out, say channel A, and then channel B is 0V?
#21 — VisibleSignals · 2020-09-24
It has two RGB buses, and each input can be routed to either the A or B bus (or neither if the Dest switch is centered). The output module has separate RGB outputs for each bus. The keyer crossfades between the A and B bus, based on the luma of bus A or bus B, or an external CV, and has controls for manually adjusting threshold and sharpness of the crossfade.
One of my goals is to start replicating some of the functionality of old home video mixers in eurorack format.
#22 — sean · 2020-09-24
Cool. Looking forward to the demos. The blue module at the far left feeds into it as well, through a ribbon cable, right? (If I am reading/remembering the other thread correctly.)
Also: love the implementation of the keyer here!
While it has at times been somewhat of a bummer that LZX hasn’t prevented “holes” in their lineup while switching gears here (albeit totally understandable for so many reasons!), it is kind of nice that it has opened up some more room for others to experiment. Not that the room wasn’t always there, but there seemed to be less incentive when it felt like a full range of options were already available. Glad you, and others, have been picking up the gauntlet, as it were!
#23 — VisibleSignals · 2020-09-25
Yes, the ‘Direct In’ module has one socket each for the red, green and blue channels. It also has the A/B bus switch too. I use that with Syntonie’s YUV input module so I can mix full colour video input with LZX patterns, colourising it and manipulating it with the keyer/crossfader section. It’s awesome and that’s why I have to put together some demo videos because just looking at those panels you don’t really get an appreciation of what’s actually possible.
#24 — Kinterjustin559 · 2020-09-25
Yeah I need to know fucking immediately who is going around telling people I’m a sketchy vendor and not to deal with me. Fucking IMMEDIATELY. This is bullshit dude. I don’t know what you think gives you the right to go around talking shit when I’m trying to raise money to feed my family. You don’t know Jack shit about me. I have never ONCE ripped anybody off in my entire life, not one god damn time. I offer a two week 100% money back guarantee on everything I sell and have never had ONE person fucking complain. This is bullshit dude. Straight up.
#25 — Kinterjustin559 · 2020-09-25
Let me guess, it’s the dude who hit ME UP and tried to convince me to ship to HIM! Which I never posted about shipping to anybody, but I agreee to do a favor for him, then he wants to turn around and accuse ME of being a scam artist? For real dude? That’s how it is here? No one asks to see any references, no one investigates to see if this person is telling the truth, just, “oh well he said it so it must be true.” And of course I let that dude know what’s up man, I don’t even want to sell my shit to begin with but as I’m sure everybody probably already knows, shit isn’t easy out here right now, and it sure as shit doesn’t make it easier when you have jerk offs going around telling people you’re a scam artist
#26 — sean · 2020-09-25
Calm down. “Sketchy” was my word, not theirs (and probably a poor choice of words, I admit). Communicating via email can sometimes lead to an escalation of misunderstandings, which is what I assume is what happened here.
#27 — Kinterjustin559 · 2020-09-25
I’m not mad at you, and I’m glad you replied, I want to know who it is that’s going around saying things like this because it is 100% not cool, and unacceptable. I wasn’t out here hitting anybody up, or actively pursuing anybody. I’m minding my own business posting in my own local area, and then all of a sudden I have people hitting ME up making go through the hassle of pitching to them and trying to get payments set up, working with my fiancée to make sure all of our financials are squared away and deciding what the best way to receive payment is that also gives people the most options, holding the stuff for them, making plans on what bills to pay because I’m expecting to get paid, telling my creditors that I have a payment ready for them tomorrow, and then all of a sudden I visit the LZX forum and my name and post is getting thrown out into the world and these dudes are cancelling on ME because I seem sketchy, even though they hit ME UP, even though I’ve gone above and beyond to try and provide excellent customer service, offering free two day shipping, money back guarantee, and by the way, I didn’t even HAVE to say anything about having to use my fiancee’s PayPal account, I did it to be honest and to have integrity. I could have just not said anything and let these two jokers pay and they would have been none the wiser, but no, instead they get butt hurt and go and try to trash my name, for what? I’ll say it again, they hit ME UP
#28 — sean · 2020-09-25
I am happy to take down the link or clarify that you don’t want to (and/or would prefer not to) deal non-locally, if that’s the case.
But, I mean, someone didn’t have a positive experience and that is what it is, as far as I am concerned (I edited my original post to be more neutral). I don’t really know all the details. Different people have different levels of comfort with various arrangements when dealing with buyers/sellers.
#29 — Kinterjustin559 · 2020-09-25
And just so everybody who happens to see all of this knows. I claimed my synth side business on my taxes last year and it’s one of my main revenue streams, and I am going to be looking into what I can do as far as libel is concerned
#30 — Z0NK0UT · 2020-09-25
Not the place for this discussion, folks. This thread is now locked. Please do not post anything else about this dispute on the LZX forum. Thank you.
#31 — Z0NK0UT · 2020-09-25
