How to fill a 2hp gap, for video synthesis?
Category: Forum · Tags: — · Posts: 6
#1 — joem · 2018-08-08
If you had a 2hp gap to fill in your video system, how would you fill it? First thing that jumps to mind for me is a passive mult. Is there anything else that’d be good?
#2 — creatorlars · 2018-08-08
I would do a passive mult or blank panel. I’m not sure what 2HP modules are out there these days, but any kind of LFO or cycling envelope is always going to be useful.
#3 — Alexk · 2018-08-08
Unity mixer or mult for sure.
#4 — destroythings · 2018-08-08
If you had bridge in your case already you could grab some like the 2HP LFO.
http://www.twohp.com/modules/lfo
In fact theres loads of modules on that site that would probably work well paired alongside Bridge.
#5 — creatorlars · 2018-08-08
Just to note, you don’t necessarily need Bridge to adapt a Euro range LFO. Most inputs can attenuate, and even if you drive them with a larger voltage, you just get a “fade in/pause/fade out/pause” kind of behavior to the modulation. Of course, 1V makes patching easiest.
#6 — creatorlars · 2018-08-08
Also, a dedicated passive mult JUST for distribution of the H/V ramps from Cortex is worth it and very useful! In a larger Expedition system, you’re going to be multing those all over the place.
