[ORDER] Distribution Amplifiers
Category: Unknown · Tags: — · Posts: 36
#1 — Fox · 2020-12-08
My first official order thread!
To fund the next (and hopefully final) revision of my RGB Switcher, I made two different Buffered Multiples. I only have 17 of each of these for sale. I will likely have more made at a later date.
20201207_150803
Description:
– 3U, 4HP, 40.64mm (1.6in) deep
– 2pcs: 1xFaceplate, 1xPCB - Module (B) - Triple YRGB Distro Amp
– 3U, 8HP, 40.64mm (1.6in) deep
– 3pcs: 1xFaceplte, 2xPCB
Both modules are of course video-rate multiples and with cascaded inputs, each module can be used in several ways. the Dual 1:3 mult may be used as a Single 1:6 mult and the YRGB mult may be used as a 1:12 mult, Dual 1:6, 1:9 & 1:3, and more!
These would be great companions for the upcoming RGB switcher which will now have a switched VC input for the threshold pot. While these are labelled for YRGB, consider using the “Y” for several daisy-chained RGB switchers.
:wink:
Available Options:
Shipping:
I’ll combine shipping for anyone who wants more than one. Reply below, or PM me to get yours!
Below you will find the BOM and photo build guides.
Thanks everyone!
-Fox
List:
#2 — Fox · 2020-12-08
Dual 1:3 Distribution Amplifier
BOM, Build guide and Schematics
Expand for BOMQtyValueParts4100K resistorR1 - R410499R resistorR5 - R142100n capacitorC3, C4210u 25v Electrolytic CapacitorC1, C221N4001 diodeD1, D2268R Ferrite BeadFB1, FB28PJ302M JacksJ1 - J812x5 (10-Pin) male headerJ91LM6172U1
Expand for Build GuidePopulate shortest parts first.
1to3BuildGuide (1)
Step 1: Resistors
R1-R4: 100k Ohm
R5-R14: 499 Ohms
1to3BuildGuide (2)
Step 2: Diodes, Beads
D1, D2: 1N4001 (Alternate 1N5819)
FB1, FB2: 68 Ohm @ 100MHz
Pay attention to the diode’s stripe.
1to3BuildGuide (3)
Step 3: caps
C3, C4: 100nF (MMLC or film box)
Optional: 8-pin DIL socket
1to3BuildGuide (4)
Step 4: Electrolytic caps, power connector
C1, C2: 10uF 25v Electrolytic Capacitors
J9: 2x5 pin male header (or shrouded connector
Pay attention to the polarity. The stripe points to the negative pin.
1to3BuildGuide (5)
Step 5: jacks
Place jacks in circuit board. Do not solder.
1to3BuildGuide (6)
Step 6: faceplate
Line up faceplate and add nuts to jacks. Finger tighten and once the jacks are straight, solder jacks.
Tighten nuts fully,
1to3BuildGuide (7)
Step 7: IC
U1: LM6172
May optionally be soldered directly or inserted in socket.
1to3BuildGuide (8)
Expand for Schematics
ModuleA_sch
#3 — Fox · 2020-12-08
Triple YRGB Distribution Amplifier
Expand for BOMQtyValueParts8100K resistorR1 - R4, R20, R21, R27, R2820499R resistorR5 - R19, R22 - R264100n capacitorC3, C4, C5, C621N4001 diodeD1, D2268R ferrite beadFB1, FB22LM6172 op ampU1, U212x5 (10-Pin) male headerCONN1210uF 25v electrolytic capacitorC1, C216PJ302M jacksJ1 - J1616-pin female stackable headermisc16-pin male pin headermisc
Expand for Build GuidePCB 1:
20201207_134946
Step 1: 100k Resistors
R1-R4, R20, R21, R27, R28: 100k
20201207_135616
Step 2: 499R Resistors
R5 - R19, R22 - R26: 499R
20201207_135835
Step 3: beads, diodes
D1, D2: 1N4001 (alternate 1N5819)
20201207_140129
Step 4: sockets
optional: 2x 8-pin DIL sockets
20201207_141357
Step 5: capacitors
C3 - C6: 100nF (ceramic, MMLC or film type)
20201207_142200
PCB 2:
20201207_142232
Step 6: resistors
R5, R11, R13, R14, R18, R19, R25, R26: 499Ohms
All resistors on this board are 499R
20201207_142559
Step 7: PCB 1 jacks
Place jacks in pcb 1 (green). Do not solder.
Remove faceplate before step 8.
20201207_144039
Step 8: PCB 2 jacks
Place jacks in pcb 2 (blue). Do not solder.
Place both pcbs into faceplate and tighten nuts fully.
20201207_143408
20201207_143356
Step 9: backside header
Users may choose to use a ribbon cable or one 6-pin stackable header and one 6-pin male pin header.
Start by connecting the male and female headers together, then insert it between the boards and solder each side. 20201207_144744
20201207_144727
YRGB_sch
#4 — 337is · 2020-12-08
Great work. Happy to support and eager to build.
DM sent.
#5 — meudiademorte · 2020-12-08
:point_up:
would take both
Shipping to germany
#6 — Robbertunist · 2020-12-08
Hi Pascal, any chance you’re in Berlin?
#7 — Robbertunist · 2020-12-08
Any of ye in need of a buffered Multiple & interested in one or both of Fox’s designs? @horacio2222@VanTa@destroythings
#8 — meudiademorte · 2020-12-08
Nope, Saarbrücken. So Far away from u.
#9 — Robbertunist · 2020-12-09
It is the other end of Germany for sure, thanks for answering anyhow @meudiademorte
:+1:t3:
@Fox, how much is the postage to Germany? It still might make more sense to ship a few to one person in Germany and they then distribute them from here, because postage within Germany is cheap. I’ve got plenty of the right angled Thonk jacks & LM6172s here.
& can even build a unit or two if someone doesn’t have the soldering know how or equipment.
#10 — Fox · 2020-12-09
I am going to find out shipping cost tomorrow. The post office has already closed today.
Looking online, a few shipping options may be:
“First-Class Package International Service” = 14.75 USD, delivery date “varies by location.”
“Priority Mail International® Small Flat Rate Box” = 37.45 USD, delivery may be 6-10 days.
I cannot guarantee these prices, but I will find out for sure tomorrow.
#11 — Robbertunist · 2020-12-09
Thanks for checking @Fox
:+1:t3:
If anyone has any tips regarding good service providers or suggestions regarding postage costs to Europe, we’re all ears :blush:
#12 — joem · 2020-12-09
It’s hard to beat the USPS prices that Fox quoted, for individuals/small companies. (Larger companies can get negotiated rates from some shipping companies.) Shipping internationally from the US pretty much always costs a lot. Might be able to get it down a little by shipping in an envelope of some kind instead of a box (if it’s just PCBs), but then you run the risk of damage with international shipments especially.
That said, putting a few pcbs together and masking-tape them together so they don’t slide against each other makes for a pretty tough little thing. A tight sandwich of cardboard with masking-taped PCBs in between, put in some sort of envelope can be a decent method. I believe that’s how Pusherman shipments are packaged, and I’ve seen similar done with a few other PCB sellers.
#13 — Fox · 2020-12-09
It’s always been tough for individuals. I hate it when the shipping is more than the products.
:scream:
Good tips. I am going to find some packaging materials to have at my house so I don’t have to buy the stuff every time I visit the post office.
#14 — wednesdayayay · 2020-12-09
if anyone is selling built modules I’d be up for one of each
#15 — Robbertunist · 2020-12-09
Cheers @Joem for all the tips, they’re good ones & I’ve received such a delivery a couple of times & everything was fine thankfully. Masking tap was a bit annoying but it did it’s job
:+1:t3:
@Fox, I’m much happier to receive recycled materials. Firms here often have bins (yellow for recycling contents) full of clean bubble wrap & boxes of various sizes. I’ve even found padded envelopes
:wink:
@wednesdayayay, I’d happily oblige but the Atlantic is an issue as well as customs. @Fox, if you’ve a bit of free time, collect some of those “value added” dollars
:grinning:
#16 — reverselandfill · 2020-12-09
I buy my packaging material at RAJA packaging. I only use paper & cardboard boxes. NO plastic!
For padding, I use a document shredder and old magazines / recycled paper
#17 — Robbertunist · 2020-12-09
Count me in for 4 of each @Fox
:+1:t3:
#18 — brdaniell · 2020-12-09
2 A please! Love the parts list on the pcb
#19 — jestern · 2020-12-09
Fox wrote:
Dual 1:3 Distro Amp
Hey this is right on time, @Fox, I’ll get 3x Dual 1:3 Distro Amp
#20 — mrfang · 2020-12-09
I’m interested in 2 PCB/panel sets of each!
#21 — Fox · 2020-12-09
@meudiademorte: 1x Each - DM’d @Robbertunist: 6x Module (A), 4x Module (B) - DM’d @brdaniell: 2x Module (A) - DM’d @wide_closed: 1x Each - DM’d @jestern: 3x Module (A) - DM’d @mrfang: 2x Each - DM’d @wednesdayayay - DM’d
I am contacting everyone now. If you don’t hear from me in the next hour, please DM me.
#22 — wednesdayayay · 2020-12-10
it would be super cool for the distro amp to have a +1V present at the outputs when nothing is plugged in!
I hadn’t considered that before but it could be very helpful to have some more static voltages in the system
just a thought for future revisions or other modules
#23 — saiteron · 2020-12-10
@Fox would love to pick up three PCB/panel sets for the YRGB distro amps if they’re still available!
#24 — Fox · 2020-12-10
Neat idea. I was working on a board that took a single input and shifted it both upward by +0.25v, +0.5v, +0.75v and downward by -0.25v, -0.5v, -0.75v. Alternatively without an input, the outputs present the above mentioned static voltages. I wasn’t sure how it could be used so I haven’t shown it off. Maybe I will.
@saiteron Sure thing, I will message you right now.
#25 — wednesdayayay · 2020-12-10
that sounds like it would be a fun modulation pal!
if you took a LFO into it and then used waveshapers/comparators/slews on the different outputs it would give a wide palette of system control.
I love the creativity keep it coming!
#26 — csboling · 2020-12-10
@Fox I’ll buy one YRGB distro amp! Awesome projects!
#27 — Fox · 2020-12-10
Excellent! Messaging now…
#28 — Maytoast · 2020-12-13
Any built ones being made? Do you have a website these will be available from? Looking rad!
#29 — saiteron · 2020-12-13
if Fox doesn’t sell any built ones, i will be building 3 soon with 2 for sale. ordering parts this coming week and should be able to build before the end of the month.
#30 — allthesixes666 · 2020-12-20
Hi, if you still have two of Module (B) left, could I take them both please?
Let me know, with shipping to the UK
thanks
#31 — Fox · 2020-12-20
DM’ing
I have 30 more of these coming soon as well as the next (soon to be tested) revision of the RGB switcher.
#32 — jsonpayload · 2020-12-31
Anyone in the US up for selling a built version of Module B?
#33 — Fox · 2021-01-04
As soon as my op amps get here, I will have some built/ tested modules available. Each will come with a 5-6" power cable. Feel free to DM me and place claim.
20210104_143134
@wednesdayayay @jsonpayloadEDIT: Updated Stock
#34 — Midcitysteve · 2021-02-18
Hey @Fox did you ever get another round of pcbs made? Id like 2x module A and 1x module B shipped to the US. Thanks.
#35 — Robbertunist · 2021-06-27
If anyone in Europe is looking for these either built or as PCB&Panel sets, I’ve got a few of both buffered Mults available.
#36 — homegrown · 2024-07-08
Just got my Fox multb and daisy and super excited to build them. Not a big deal but thought I’d give a heads up that there is a missing step in the build guide (for the trip YRGB mult) to populate the two 10uF electrolytics.
