4MS Quad Pingable LFO
Category: Unknown · Tags: eurorack · Posts: 5
#1 — phosphenes · 2021-03-01
Just got a great price on a 4MS QPLFO, very excited to have a new modulation source in my system! Thought I’d start a thread to see if anyone had any tips and tricks for using it (mostly to help contain my excitement before I get home).
#2 — jwsmithwick1 · 2021-03-01
One thing to keep in mind is the sensitivity trimmer on the back that sets the voltage threshold level that “pings” the lfo. This can be adjusted down into the 0-1V range so that LZX signals can trigger the lfo.
I had a related problem when I got my QCD. The sync out from my drum machine wouldn’t trigger the clocks. I adjusted the sensitivity trimmer down until the sync signal began to trigger and everything began working. Much fun, enjoy!
#3 — eraxeg · 2021-03-04
Also another thing to keep in mind is that you may want to attenuate the output. From the specifications:
Bipolar/Unipolar jumper:
- Setting jumper to Bipolar makes the outputs -5V to +5V
- Setting jumper to Unipolar makes the outputs 0V to +10V
- One jumper controls all four channels
#4 — phosphenes · 2021-03-04
Thanks! Yes i’ve got it set to +/-5V and literally just finished reconfiguring my cadet scaler to be +/-5V to 0-1V. Having a lot of fun with the QPLFO so far!
#5 — Rik_bS · 2021-03-04
The manual has a few good tips for cross modulation, or if you have another modulation source then cross modulate it with the QPLFO.
Clocked modulation is fun, we all like repeating patterns - but make sure they’re not too repetitive
