Visual Cortex Output Appears to Have Died
Category: Helpdesk · Tags: visualcortex · Posts: 2
#1 — akavalve · 2021-07-01
I’ve had my VC for a number of years and it’s always run as expected. Currently the end of chain is VC to a composite to HDMI converter to a BM Assist.
Last night in the middle of using the system the BM Assist screen went blue indicating no signal. I swapped the feed to the HDMI upscaler from the VC to the composite out on the ET Structure and signal appeared on the BM Assist screen. I plugged svideo out from the VC to a known good monitor and got no signal. So I think the VC output section has died.
Are there any other tests I should run to confirm this?
What is the path to repair if it is indeed dead?
#2 — Z0NK0UT · 2021-07-01
Sorry to hear it!
You could check the Cortex’s YPbPr output, but if you want the composite output, then it would be best to send an email to support@lzxindustries.net to begin an RMA. Be sure to include your return shipping address and phone number in the email.
