Part for changing out a composite output on the Visual Cortex
Category: Helpdesk · Tags: visualcortex · Posts: 7
#1 — LauLindqvist · 2018-09-04
Hey, i have a visual cortex used at the school i work on. Some random student tried using a 3,5 mm patch cable on the composite out and broke off the tip. I tried various extraction atempts, but have now realized that i need to change the RCA connector. I have built 30+ cadet and castle modules and feel confident that i can replace it without destroying anything
But searching around at mouser i do not see any parts that looks like the ones used, can you provide a part number at mouser for me? I have an order at mouser coming up in a few days, and would like to include this part. Thank you!
Best. Lau! IMG_9132|375x500
#2 — creatorlars · 2018-09-04
https://www.mouser.com/ProductDetail/CUI/RCJ-051?qs=%2Fha2pyFaduhF6JgJ2vUH6DiyQ6ieoHomrE5QENdb0V4%3D
#3 — peloazul · 2018-09-04
I (successfully!) replaced one of the RCA connectors on a War of the Ants that I own - and I want to wish you the best of luck! (What I assume is) lead-free solder is no joke! I am definitely not a DIY novice either, have desoldering specific tools, and I found it to be quite a 3D challenge. I gave up and removed a jack to have more room to work. The solder really wanted to stay put in the through-holes.
If I were to suggest anything, I think a little hot air will speed up things quite a bit (if you are comfortable with using it).
#4 — creatorlars · 2018-09-04
This stuff and good quality copper braid are your pals!
https://www.amazon.com/ChipQuik-SMD-291-Clean-Syringe-Nozzle/dp/B00CM2A97S
#5 — peloazul · 2018-09-05
That’s certainly what I used for my repair.
I still found it harder to work with than good ol’ Leaded Kester 331.
#6 — creatorlars · 2018-09-05
Yeah, leaded solder is always much easier to work with. Part of it with those RCA jacks is that the whole jack shield acts like a big heat sink; next time try a big, chunky tip on your iron to increase its ability to take the thermal load. (I’m of course making assumptions here.) Lead free solder has a higher melting point, so the thermal load is also high due to that.
#8 — LauLindqvist · 2018-09-05
Thanks all. Hadnt thought about the non-leaded solder situation, guess i will get my electronics technician friend to help out here, im using his workshop anyway.
And thanks to Lars for the parts link!
