Chromagnon inputs
Category: Forum · Tags: — · Posts: 3
#1 — dryodryo · 2021-10-17
Hi,
Will the Chromagnon RGB inputs be able to handle anything other than LZX formatted video? My guess is no. It would be super sweet to just feed it a VGA signal, but I’m not seeing any Hsync or Vsync inputs on the front panel graphic.
So the highest quality input to the Chromagnon would be YPbBr with sync on Y?
Thanks
Aaron
#2 — Z0NK0UT · 2021-10-18
I moved your question to the main Chromagnon thread. See my answer here:
The Chromagnon RGB inputs use the 1V LZX modular video standard. Some folks have used Extron gear (as illuminated in other threads) to send RGB signals directly. TBC2 has an optional VGA expander, but you would have to convert VGA to component if using only Chromagnon.>
