Navigator - no LEDs
Category: Helpdesk · Tags: navigator · Posts: 7
#1 — Traviss · 2024-06-21
As the title states my navigator has no LEDs glowing and doesn’t appear to be spinning / morphing my ramp input. Could I just not be using it correctly which is likely, or does it seem like there is an issue of this is the case?
Cheers
#2 — Traviss · 2024-06-21
Could it be that the RCAs on the back were not connected / synced to the Visual Cortex correctly? I would test myself but this happened away and I need to set my rig back up, cheers.
#3 — Z0NK0UT · 2024-06-21
How are you powering and syncing the module? No LEDs typically indicates that the module is not receiving power and no rotation usually means it is not receiving a sync signal.
#4 — Traviss · 2024-06-22
Hi Zonkout yes the idea that there was not enough power makes sense and I can test this soon. With the Sync cables on the back going to Visual Cortex I’m pretty sure I had both sync Outs going to Sync Ins I hope that’s the correct connection.
#5 — j4s0n · 2024-06-23
Think of the sync chain like a one way street. Visual Cortex “sync out” to Navigator “sync in”, and so on to other modules that need sync. It’s not a loop. There should be a “master” and everything else should be “slaves”. There might also be a “termination” switch on some older gear. That should only be on for the last module in the chain. A “star configuration” is also possible if you have a sync distro, but that’s another can of worms.
#6 — Traviss · 2024-06-24
Thanks I obviously had a loop set up with the sync cables then, thanks for clarifying that. I really think it’s a power issue, will test today and update here later, cheers!!
#7 — Traviss · 2024-06-24
Yes it was just a lack of power issue, admin can remove or modify the thread if they prefer to.
