Display for Double vision
#1 — Stevea · 2026-04-24
I run the DV into a macbook pro running obs
I noticed in your getting started first patch you go directly into a nice display can you advise what this is as it looks a lot nicer and or any others you recommend. Sorry if that’s a bit dumb but I’m still early in my learning journey and try to avoid costly mistakes
The issue with the macbook approach is that I’m not confident I’m getting the best look and performance due to cheap hdmi converters etc. I’d rather pay more to get the best results
Thanks so much
Steve
#2 — Stevea · 2026-04-30
I think I have found my solution . The BMD video assist or ninja v . With a quality cvbs to hdmi or sdi converter. Probably BMD as well
Any thoughts?
