What's the best way to directly capture video from the Vidiot?
Category: Helpdesk · Tags: capture, vidiot · Posts: 4
#1 — DoctorWhopper · 2018-09-28
Hi all, I’m trying to capture video from the Vidiot to playback in a video player. What’s the best way to do this?
#2 — Tan_Sat · 2018-09-28
Shooting off your monitor with a digital camera is probably the easiest. Helps to have a camera that you can manually set and lock the shutter speed. DSLRs work well. Obviously you are gonna want to use a tripod.
Other than that you can use a capture card/device. I’ve had luck with the Blackmagic Shittle Intensity.
#3 — sector · 2018-10-16
i´m using supercheap composite to usb converter, they´re like 15 bucks top. it get the job done, if you want something superior look for a black magic intensity shuttle, or any other video capture device
#4 — DaisyC · 2021-07-27
I’m using a computer screen recorder to save what I want. It is able to record videos in HD or 4K quality. It is easy to create lag-free and watermark-free videos. Maybe you could give it a shot.
