Capturing Vidiot with Blackmagic Intensity Shuttle - Settings?
Category: Unknown · Tags: capture, vidiot · Posts: 5
#1 — Bengt · 2018-10-09
Hi!
Just got my Vidiot and now I’m trying to capture the output with my Blackmagic Intensity Shuttle (thunderbolt version). Anyone who knows what settings to use? So far I’ve been trying an endless amount of combinations without any luck.
Thanks!
#2 — peloazul · 2018-10-09
(Disclaimer: I have neither a Vidiot nor an Intensity.)
Reading through the Vidiot manual - it seems the only color output is composite, so that’s what you want to select in the “Desktop Video” app. As to format, it will be either NTSC or PAL, I’d guess. Try that and see how it goes.
On the back of the video is RGB out but this is different than YPbPr (YCbCr?) which the Intensity will expect if you select the Component inputs.
#4 — wednesdayayay · 2018-11-24
what software are you using to capture with?
what OS
windows or mac
#5 — Agawell · 2018-11-24
i would’ve thought mac with thunderbolt
probably with the software bundled
not tried it myself as i don’t have an intensity shuttle, but another option, i believe, is black syphon to syphon recorder - which would also let you pass through lumen (or any other syphon application) on the way if you were so inclined
#6 — Dewb · 2018-11-24
BlackSyphon is handy to have around for testing. So is the Resolume free demo, it has good built-in Shuttle support, free version is watermarked but is otherwise fully functional.
Some troubleshooting steps: (all things that have tripped me up at one time or another):
