Eurorack Glitch Modules
Category: Unknown · Tags: — · Posts: 64
#1 — a_digital_index · 2018-10-10
Are there any Eurorack Glitch video modules being made? Most Glitch hardware seems to be modded older gear. I’d love a Tachyons + unit but really need to keep to the eurorack form factor.
#2 — sean · 2018-10-10
Don’t think it’s out yet — or even know exactly what it does — but I’ve seen that BPMC has been working on the Fluxus Duo.
#3 — creatorlars · 2018-10-11
Fluxus Duo! I’ve personally assisted BPMC with the design on this one and it’s great. Two identical glitch processors with an LZX style CV crossfader between them.
#5 — creatorlars · 2018-10-11
Many glitch effects rely on destroying or amping the color subcarrier itself, and are therefore reliant on composite video encoding (which in the LZX patching standard uses yellow RCA jacks)
#6 — peloazul · 2018-10-11
Going to need more TBC2 and C2.
A neat module might be a video analogue to one of those audio send / return modules meant for interfacing with outboard gear / pedals.
#7 — creatorlars · 2018-10-11
For glitch style effects within an RGB ecosystem, I imagine Memory Palace will be quite fun when modulated by noisy stuff.
#8 — creatorlars · 2018-10-11
Visual Cortex! Or a slimmer encoder module to pair with TBC2.
#9 — peloazul · 2018-10-11
Oh - I would worry about wasting the output from the VC as it is usually the endpoint before monitoring and capture. (Could always have two
:rofl:
.)Thinking of the use case of putting glitch in-line with synthesis before mixing. E.g having synthesis -> glitch -> mixing (VC/MI).
#11 — creatorlars · 2018-10-11
The thing about glitch is that by nature, a proper TBC/frame sync will tend to remove or minimize glitch effects. They can also be very contextual to the display you’re using. So for a send/return scenario, I’d recommend rescanning the glitched output on a monitor before feeding it back into the system.
#12 — creatorlars · 2018-10-11
With TBC2, we’ll have some ability to have superuser style options in the settings menu though, with some options to be tolerant or cope with different types of glitch input. It’s not going to be the same as how the signal will look on a CRT though.
#13 — a_digital_index · 2018-10-11
I take it from this comment that the preferred method for capturing Glitchy bits is to record the screen?
Some of the artifacts may get get lost if recorded into a VTR or captured to computer right?
#14 — peloazul · 2018-10-11
That’s how I took it. If I follow, the process of TBCing something glitchy removes some or all parts of the glitch.
#15 — creatorlars · 2018-10-11
Yes, correct. Any changes to the signal that cause lack of broadcast standard sync are going to be dependent on the display to some degree. You can think of LZX format kind of like an “anti glitch” device (any signal in, standards compliant video out.)
#18 — creatorlars · 2018-10-12
No, the glitch effects in question (rainbows, chroma distortion) are related to the color subcarrier itself. You can process Luma+Sync only stuff on the Component standard already (This is the green Jack in YPbPr)
#19 — drumasaurusrex · 2018-10-12
I’ve gotten fun “glitchiness” by running video signals through Eurorack audio samplers like the Make Noise Phonogene and 2hp Freez. I usually mult some part of the patch signal and put it through the sampler and then mix it back in to some part of the patch. Modulating the sampler will change the degradation and playback of fragments of the [higher bandwidth] video signal. I have also used the Mikrophonie module to touch-glitch video signals directly or as a “button” for tweaking the sampler in such an approach. The effect does not match typical “glitch” (sync mess / color amplification / edge distortion), but it is fun for altering the quality of your signal. And it all happens upstream of encoding so it doesn’t hurt your sync signal in the end.
The new BPMC module sounds like a load of fun!
#20 — wednesdayayay · 2018-10-12
I had a good time the other day playing with a sync signal going into a prismatic ray
instagram.comhttps://www.instagram.com/p/BnzNxArFsm1/image
https://www.instagram.com/p/BnzNxArFsm1/13 Likes, 0 Comments - Nichole Pichon (@nicholepichon) on Instagram: “#lzxindustries #lzxvisualcortex #lzxprismaticray #lzxpassage bending sync. H sync from visual…”Link: Nichole Pichon
this was just with passage I haven’t explored further
fun stuff
Looking forward to seeing what this new module can do
#21 — pbalj · 2018-10-15
i’ve got a few glitch processors in the works. also castles can get really glitchy very easily. unsync things, do feedback modulation, reorder the outputs, etc
#22 — dni_br · 2018-10-15
yes or just patch the pr component output of a cam in the y component input of visual cortex. Instant glitch
#23 — a_digital_index · 2018-10-16
Working on getting the Castle Completed. Interested in the upcoming Glitch Processors. Thanks
#24 — dni_br · 2018-10-16
May be the TBC2 could have some kind of controlled unsynchronisation ?
#25 — sean · 2019-04-08
Fluxus Duo pre-order is up.
Will probably have to wait until I’m a little more flush with $$ to pick up one of these guys. But glad to see it finally making it out into the world!
#26 — catbiscuits · 2020-01-03
I got mine. Very cool. Anybody want to add it to Modular Grid?
#27 — rempesm · 2020-01-04
It’s up there but under the other/unknown category: https://www.modulargrid.net/e/other-unknown-bpmc-fluxus-duo
#28 — catbiscuits · 2020-01-04
Thank you!!! That’s great.
#29 — trbsnd · 2020-01-06
syntonie.fr works on a eurorack version of the ave mod v2.2… i already euroracked mine as well
#30 — rempesm · 2020-01-06
Awesome, I’m just in the middle of stuffing the board for my AVE Mod. Do you have a panel file you could share?
#31 — trbsnd · 2020-01-08
yep sure you can load the laser cut files from syntonie on his github:
https://github.com/Syntonie/documentation/blob/master/AVE%20MOD/AVE_MOD_V2.2_Laser_Cut_Enclosure.ai
made this one out of it:
Screenshot 2020-01-08 at 11.21.15
#32 — rempesm · 2020-01-08
Awesome, thank you! I’m going to try to squeeze some labeling on there, too.
#33 — Grain · 2020-02-01
O M G …
Yes!!! 2020 looks like it’s gonna be a lot of fun.
That beast just jumped the the very top of my want list!
Thanks for sharing.
#34 — sean · 2020-07-17
CBV-001 (Eurorack AVE MOD) out from Syntonie!
Syntonie
https://syntonie.fr/produit/cbv001-circuit-bent-video-enhancer/(First small batch of kits/built modules ready to ship on July 20th, next batch expected…
Link: Syntonie - Video DIY
Works with both composite signals (in full RGB) and LZX 1v (in B&W)!
He also has some other modules out today too. Available built, as kits, or panel + PCB.
#35 — reverselandfill · 2020-07-17
those modules are super cool!
especially the frequency doubler and the component input!!
#36 — sean · 2020-07-17
Yeah, I ordered the CBV001 (AVE MOD) and the freq doubler.
Had to control myself and not go 3x the CBV001. Would be cool to be able to run RGB channels thru them internally in the LZX environment. But kind of had to be realistic about my available rack space.
#37 — reverselandfill · 2020-07-17
I ordered the CBV001 , VU002 and VU003 !!
these are great projects!
#38 — Genlok · 2020-07-17
I ordered the quad frequency doubler assembled, and then PCB+panels for the AVE mod and Component2RGB modules. These are going to be fantastic!
#39 — syntonie · 2020-07-21
@sean thanks for the share and for you order!
CBV001 can process LZX signals, however I kept the signal path AC coupled as on the original archer circuit which is meant for composite, so offsets doesn’t really affects it, and in/out impedance are for composite rather than LZX (input impedance changes with the JFET and CV also), so it’s not really optimized for it, but got nice results coupled with the Cadets and VU. The idea was to keep it simple without adding too many extra components.
VU (Video Utilities) are properly terminated as per LZX standard with 100k to ground at the input and 499ohm in serie for the outputs (except for Composite/Component IO).
A triple CBV001 to process RGB (or VGA in standalone) could be great, I think Phil did something like this for VGA sometime ago. The number of controls on the CBV001 could be reduced (remove stuff that mainly acts with chroma for exemple), enhance is voltage controllable so controlling all 3 would allow for a dirty fade to black kind of thing, then I would love to be able to have the same kind of control on the glitch effects.
Been experimenting with JFET as voltage controlled resistor (as it is done for the CV, which is just acting on the input impedance, changing how much the signal is divided at the input), but this configuration requires a path to ground, so not always easy to adapt to existing glitch effects.
I’ve been processing Component converted to RGB using VU003 with 2x CBV001 and Fluxus Duo, needs some precise setting to have some glitch while keeping a good color balance, but definitely interesting.
Wish you a good build!
#40 — syntonie · 2020-07-21
Thanks @reverselandfill can’t wait to get to build your boards!
And thanks @Genlok!
#41 — reverselandfill · 2020-07-21
Good to have you here!
#42 — sean · 2020-07-21
Even (and especially) if things get a bit unpredictable with CBV001, I’m looking forward to it! Judging by your demo, certainly seems capable of some interesting results with LZX signals.
And now curious how its output will look when used as a CV source for LZX modules that have the AC/DC switches on certain inputs.
#43 — destroythings · 2020-07-22
Just grabbed myself a CVB001. Can’t wait for this!!
#44 — sean · 2020-07-29
My CBV001 just arrived this afternoon and, wow, so far loving the different flavors of edge feedback possible with it. I use feedback a lot in my LZX system, but it often tends towards one specific look. Whereas pretty easy to quickly dial in a lot of variety with this little guy. Great work, @syntonie!
CBV001_TestCardGirl_200728
(Above images use CBV001 in combination with Cadet Hard Key, Castle ADC, and Castle Multigate.)
#45 — syntonie · 2020-07-29
Looks super great!!
Thanks for the feedback!
To answer your previous question about AC/DC coupled inputs: since the output of CBV001 is AC coupled, you’ll probably won’t notice a difference when switching the AC/DC switch on the module you’re sending your signal to, however I only have tested with Cadet/Castle so all inputs are DC coupled if I’m not mistaken.
#46 — Tremendm_Labs · 2020-08-11
@syntonie we received our AveMod modular today! We cherish our AveMod V2 so much we wanted the modular asap. Thanks for developing this for modular use.
#47 — destroythings · 2020-08-11
I also received mine last week and got it set up over the weekend.
Been having loads of fun with it.
Great work @syntonie. Excited to see what you come up with next!
#48 — Robbertunist · 2020-09-28
Is there anyone in Berlin who wants to build &/or do a group buy for the necessary components, PCBs & Panels for the #CVB001 or any of @syntonie’s other DIY modules?
#49 — reverselandfill · 2020-09-29
it has to be in Germany? Else I’ll be willing to help you (build / or make kits)
#50 — Robbertunist · 2020-09-29
Hey Martijn
:wave:t3:
Myself and other admins of the Berlin Modular group have setup up previous workshops for building DIY modules. This would be the first attempt to do the same for a video synth module.
I’d love to do something like a coordinated build session that we could also coordinate & stream online. It’d be really fun to time it so people across various locations & timezones could either join in from home or with others at a hacker space or a shop where some soldering could be done & the finished modules tested.
Okay, back to reality. Do you have the CVB-001 Martijn? Do you know other people in your area that would be interested in joining you to build one?
#51 — reverselandfill · 2020-09-29
I have build the CVB001 recently. (and both the VU002 and VU003)
These are great modules.
I know some people in the Netherlands who would be interested, but I currently live in Italy
A build stream sounds wonderful. and even very do-able . via Zoom / Skype or some other creative streaming platform
#52 — Robbertunist · 2020-09-29
I also want to build some of the modules offered by yourself (@reverselandfill) & @syntonie .
An online stream would be great, especially if @creatorlars & the LZX team @Z0NK0UT were interested in getting involved. And also a live stream & interaction with the public for the release of the #chromagnon#chromagnon would be great.
Some of this is getting way out of the boundaries of the original post, time for a new channel/subject.
#53 — VisibleSignals · 2020-09-30
I have also built the CVB001 and VU003 and they are both excellent! Please support Bastian (and Martijn) with their DIY endeavours. Getting a DIY PCB ready for sale to the public is a lot of work. DIY is amazing fun!
#54 — syntonie · 2020-09-30
Keep me updated if you were to do an online build session, would love to come and help if needed
#55 — VanTa · 2020-10-01
I’m in Berlin, just built my CVB001 but I’d join for anything DIY/video related.
:smiley:
#56 — acidk · 2023-05-06
Super frustrating topic for me - seriously!
My assumption: Buy glitch modules and glitch your structure output(s).
Reality:
:skull_and_crossbones:
:face_with_spiral_eyes:
I never heard of time based correction (TBC) before - but if you are new to the world of video synthesis - ensure to watch ALL of YOVOZOL gear videos, but this one here is a must:
https://www.youtube.com/watch?v=so7Mk16wGrA - Changing the TBC settings on V4 (he is demonstrated the procedure on the V8) did not help anything at all.
Currently, I am trying to mix the chaotic Structure with a the second with much more subtile settings.
TBC2 seems to be available nowhere in Europe
:disappointed_relieved:
#57 — meudiademorte · 2023-05-07
It needs time till tbc2 is available in the EU. Lzx is still fullfilling Tbc2 pre orders made years back. Schneiders allready got a few batches, so i have one but tbc2 will probably not solve your problems. Tested it with cbv001 and it drops out quite often. Easiest way is to rescan a crt or use a mixer with a glitch resist tbc inbetween (but if you are flo, u already told you on the fb forum)
btw its quiete easy to find the syntonie glitchers. They are most of the time in stock at the syntonie website / raw voltage / thonk (diy)/ Schneiders.
#58 — acidk · 2023-05-07
Thanks! Yes - I am flo
:innocent:
If I could get my hands on a sima sfx, I am going to pull the trigger (depending on price - no idea, about pricings, but some offers for 2k really scared me). The relatively small size of the Edirol is a big plus for me).
Apart from the Syntonies, there does not seem to be much more alternatives in Eurorack format.
Also a big thanks for the TBC2 comment. It’s not a cheap module and I wouldn’t mind to avoid buying it.
I am going to give the rescanning a try (I wish I had a slightly larger PVM of 8" instead of 5").
#59 — meudiademorte · 2023-05-07
Freedom enterprise and lofi future doing also affordable composite eurorack glitchers in europe / uk. But i dont know if they are also working in 0-1v lzx standard.
Tbc2 is not cheap and the unit you are looking for if you want to stabilize glitches (maybe this changes with future firmware updates), but if you want 2 inputs at the same time in your system its the way to go.
#60 — acidk · 2023-05-07
For sure, you end up easily at this price while buying two de- and encoder separately
:laughing:
I have an eye on Chromagnon
:heart_eyes:
#61 — meudiademorte · 2023-05-07
Maybe the next misunderstanding: if you want to have 2 input sources, you need a player / scan converter with genlok, so you can genlok the unit to the sync of your system.
So tbc2 makes this much more easy. Just plug and play.
#62 — joem · 2023-05-07
I didn’t see mention of it yet in this thread, so I figured I’d mention the sync_ope: sync_ope – underscores
It’s designed to help keep sync stable when doing glitch processing. It replaces the sync in the glitch output with a copy of the sync from the original pre-glitch signal. It doesn’t fix all issues, but it seems to help a bunch. @cyberboy666 designed it, btw.
#63 — sean · 2023-05-07
For what it’s worth, seems like SyncOpe should still be considered rather of a work-in-progress as well. See this thread on Scanlines for updates:
scanlines – 21 Apr 23https://scanlines.xyz/t/sync-ope-sync-restoring-circuit-next-revision-ideas/317/39current projectsopen-sourcecircuitryanalog-videodiyNot sure what can be causing this, as the sync pulse seems to be amplified a bit, but not as much as the burst, so there might be some filtering going on, though I’ve simulated the send subcircuit and everything looks fine. When it comes to the...
Link: Sync-ope : sync restoring circuit - next revision ideas
#64 — acidk · 2023-05-07
Thanks! Looks awesome and would have been an instant buy for me.
Unfortunately all options are out of stock.
#65 — Marizu · 2023-10-23
I know that some glitch devices can output significantly higher voltages than the 0.7v in a standard composite video signal.
Are TBC2 and Visual Cortex able to take these voltages without risking damage?
#66 — Z0NK0UT · 2023-10-24
I have not heard of any issues from people using glitch devices or circuit bent gear with TBC2 or Visual Cortex.
#67 — acidk · 2023-10-31
Ok - I removed the feedback loop and use go now from a camcorder–> CBV1–>CBV2–> Structure Video In → Structure Video Out → EDIROL V4 IN.
The signal I rock solid and stable. I never end up with a blue screen again and can do the entire mixdown on the V4
:heart_eyes:
#68 — G-lo · 2023-11-01
I had done the same: hoping to use glitch stuff to ease the “dgitalness” of Structure. I still do for CRT capture when I can connect direct. But otherwise, I reverse the path. The Structure does a great job keeping the signal alive without blue screens.
