Newbie Questions
#1 — jambirn · 2018-11-10
Hello,
I’m a Eurorack customer since around 2008 with about 12U of audio modules. I’ve been lurking on the LZX sites for about a year, and am dying to take the video module plunge. I’d be so grateful for answers to a few questions in light of the new Orion Series modules coming out:
- Is Visual Cortex still the best module to start with, or will any of the Orion modules replace its core functionality?
- My goal is for video reactivity to audio…I’d like my Euro sounds to trigger wacky colors and shapes, and understand that Sensory Translator will serve that function. Do I wait for Diver, though? Will the Sensory Translator be made obsolete?
Thanks so much —
Jim
#2 — Agawell · 2018-11-10
to start with you need to get something that works as a video synch generator - so the options are visual cortex, memory palace, vidiot or cadet synch generator - and then you can expand from there
visual cortex, vidot and cadet are analog, memory palace is digital
vidiot has also audio interactivity
sensory translator takes a wide band mono signal and filters it into frequency bands that it generates envelopes from
Lars says that diver is better for extracting rythmic movement from say a bassline though
so the simple answer is get both they are complementary
but you can also reuse envelopes/lfos/vcos from your eurorack via either bridge or scaler
I have a slightly smaller eurorack than you do 6u 104hp + a bit more
I have the Visual Cortex and Sensory Translator along with a few other modules including bridge - some of which at least should be delivered this week - and I’ve built a few diy modules including scaler whilst I’ve been waiting
#3 — jambirn · 2018-11-10
Thanks so much for the response. I like the idea of manipulating video digitally, but could you or someone else explain whether I can start with the Memory Palace and expand from there with other suggested modules? I’d like to generate shapes, manipulate feeds from a camera and from online videos, and most importantly, sync everything to audio/rhythms. Newbie question!
#4 — Agawell · 2018-11-11
from what I can remember Lars has stated previously that whilst the Memory Palace can be used as a centre of a video synth system, it’s really designed more as a final stage
just refreshing my memory of the specs I see that the only video inputs are:
Five 1V DC patchable video inputs for Aux, Alpha, Red, Green & Blue channels at 480i/576i SD resolutions.
so the big question the is can you support that??
what do you have in the way of video outs at the moment? & what can you get adapters for?
personally I have a macbook pro outputting either vga or hdmi, which I will convert to component using a cheap adapter (recommended somewhere on here though) and then into the Visual Cortex (this week I hope!!) which would give the 1v a,r,g.b outs for input into the Memory Palace - otherwise a tbc2 or perhaps cadet modules could do this (not sure about synching with cadet)
#5 — jambirn · 2018-11-12
Thanks Agawell. Can you or someone else let me know how best to get video out of a Macbook Pro and into the Visual Cortex?
Thank you–
Jim
#6 — Agawell · 2018-11-12
if you search for what hardware is needed here you should be able to find it quite easily
as I stated above I’m going to go
macbookpro (lumen/praxis_live) -> usb-c -> vga/hdmi adapter to component -> visual cortex
back out though is visual cortext -> component -> crt tv -> webcam -> macbookpro ( lumen/praxis_live - so can record with syphon recorder)
visual cortex -> component -> flatscreen tv -> iphone
may look at a BM intensity shuttle (or 2) next year - one for input one for output
