Blackmagic intensity shuttle success mac
Category: Helpdesk · Tags: — · Posts: 7
#1 — wednesdayayay · 2018-11-24
so I found a crazy good deal on black magic intensity thunderbolt shuttles on ebay and bought one
I’m using mac 10.10.5
I downloaded the software here https://www.blackmagicdesign.com/support/family/capture-and-playback
for reference my download was 10.11.4
the shuttle immediately showed up in the desktop video software panel when plugged in via thunderbolt
the black magic media express software doesn’t seem to want to open on my operating system (from the download 10.11.4 os is 10.10.5) so I was going to try quicktime for capture as a short term solution
then I tried the closest powered video source which happened to be a nintendo switch
so I plugged the HDMI output from the switch into the HDMI input on the shuttle
I changed the input to HDMI on the blackmagic desktop software panel
I opened up quicktime and went to file>new movie recording and selected the shuttle as the input via the selector next to the record button
the switch via didn’t show up at first
then I powered the switch on and and by pressing the home button and then it showed up on my computer screen!
success
I recorded some donkey kong with quicktime
so naturally I went to plug in the component output from the LZX system next
and nothing showed up like it did for the switch
I tried messing around with a bunch of setting and no such luck
so this morning I went back to the link I posted earlier and downloaded and older version of the video desktop software bundle
I looked for my operating system 10.10.5
and found a couple that I ended up downloading
10.9.4
10.9.5
10.9.7
within one of these versions (possibly all three I don’t remember) was a version of the media express application that worked on my system! yay
so during all my testing with these older versions apparently I had my cable plugged in incorrectly (thunderbolt) so the shuttle didn’t show up in the black magic panel when I had versions .4, .5, or .7 installed. This was because of my cable orientation though
I know that because when I reinstalled the original version i had downloaded to begin with (10.11.4) I flipped the cable and it showed up immediately
but that left me with the newest (again 10.11.4) version of the blackmagic desktop video software and also (only because I preemptively copied it onto my desktop ) a working version of the media express software
so far in my short time with it this morning it seems like as long as I have the video input set correctly (via the blackmagic desktop video panel) and media express software preferences set to the same resolution of the video coming in then it shows up and captures perfectly
this is the output from media express into a 1080p frame in final cut
I think I’m starting to get this figured out
I’m got a lot more testing of various cameras and equipment directly plugged into the shuttle
I’ll get some pictures of the whole setup including setting when I get back home
#2 — Nader · 2019-10-07
HI, would you share your project settings and capture settings on the BM media express, i seem to get lots of artifacts (sharp teeth) when capturing
#3 — Daisuk · 2019-11-21
Yeah, I’d also love to hear what exact settings you’re using for this setup.
#4 — wednesdayayay · 2019-11-21
I can get it back out but I’ve been having issues with my ~2014 macbook pro where I have to disable the thunderbolt connection otherwise it will just start shutting itself off over and over and over
kinda of stinks… as I really enjoyed this setup
I think I’ll have to invest into one of the BMD standalone recorders and get rid of this one
as a side note if anyone has a similar issue with their macbook pro this is how I fixed it https://outluch.wixsite.com/rmbp-crash
#5 — JerriB · 2023-09-29
hello!
Is i understand right, the problem with you macbook pro 2012 was the thunderbolt ports? Because i am trying to have either Mini Matrox Mx02 and Black Magic with Thunderbolt to get recognized from my Macbook in the system profiler, and nothing show up! I made a test, and connected a thunderbolt adapator to a projector and the image show up in the projector, but in the system profiler, still is saying it does not recognized the adaptator.
Was it the problem you had ?
#6 — wednesdayayay · 2023-09-29
no my problem is described at the link I posted.
essentially the computer would just shut off randomly and more frequently the longer the problem persisted.
I forget what they said the hardware issue was but it talks about it at the link.
It sounds like you are only having the issue of not seeing the device.
#7 — acidk · 2023-10-02
Do you use an Intel- or M-Mac?
M1 and M2 are (obvousy) not supported anymore by BMS.
(No problems on my 2019 Intel Macbook).
Thanks again for being part of this awesome community! > Some answers of questions nobody has asked > >>>> - but maybe it could be useful for people starting on this topic like me two months ago, saving a lot of money > >>>> > I do not own any LZX-module yet (shame!) > Core modules of my setup are currently two Erogenous Tones Structure! > Capture devices mentioned here are reflecting some personal experiences for MacOS (can’t comment on any solution for Windows). > Everybody recommended the Blac…>
