Pendulum AC/DC Switch
Category: Unknown · Tags: acdc, pendulum · Posts: 2
#1 — Nemesis · 2018-11-26
I recently got an lzx pendulum and had a question about the ac/dc switch. Looking at the user reference card it is labelled mode. My question is how does this impact the level knob and incoming cross VC? Just want to make sure I understand the module correctly. thanks.
#2 — Nemesis · 2018-11-29
For other people looking for this answer, I feel like it got a good response here:
James’ answer is good!  To put it another way, turning AC mode on is removing any slow moving content from your modulation source.  It’s a high pass filter with its cutoff at frame rate. > With a positive DC biased signal (like 0-1V video) the signal is always additive. If you add it to a mix, the mix becomes brighter.  If you subtract it from a mix, the mix becomes darker.  You are modulating brightness. > When you AC couple this signal, rising voltages will add, but falling voltages will subtrac…>
