Andor 1 Update (Beta)
Category: Uncategorized · Tags: andor1 · Posts: 6
#1 — paulslocum · 2019-02-20
I’m working on an update for the Andor 1 player. Below is a link to the latest beta version of the software, which you can install by copying the file to your USB drive and then opening the Andor 1’s menu. This update to the software fixes a few bugs and adds a couple of features like MIDI channel selection. It is pretty well tested and should not cause you any issues, but please let me know if you find any problems.
I probably will not add any more major features will this release, although I’m looking into adding the ability to force specific HDMI resolutions and refresh rates. I will be posting another beta release in a week or two.
http://www.andorgallery.com/files/andor1_v1.044.update
The changes for version 1.044 are:
#4 — paulslocum · 2019-02-21
FAT32 works directly with both Mac and PC, but the file size limit is 4GB. NTFS is good but doesn’t work directly with Mac. Use HFS+ if you’re on Mac and don’t have an NTFS driver, but make sure you eject the disk from your Mac before pulling the drive each time.
#5 — 337is · 2020-12-06
paulslocum wrote:
version 1.044
Hi @paulslocum! Thanks for the exceptionally useful tool!
I’m checking in to ask if version 1.044 is the most recent update of the Andor 1 software?
#6 — paulslocum · 2020-12-09
Thanks! It is still the most recent version, and although 1.044 generally works fine and has some new features, I recommend sticking with the original version if you’re doing a lot of syncing because the sync algorithm works slightly better. I’ve been slowly working on an update that fixes some issues and adds a lot of new features. I’m hoping to release it sometime next year.
#7 — 337is · 2020-12-09
Thanks for the reply and helpful tips. Best of luck with your work on the next update.
#8 — Andor1user001 · 2022-03-25
Two things:
