How should I sync several Cadet IV VCOs
Category: Helpdesk · Tags: — · Posts: 6
#1 — visualex · 2019-05-08
Hi! I have a visual cortex, and it can sync one of my cadet VCOs via the 14pin, how can I go about syncing further VCOs? I have only one output on the VC and I cant see a direct way to daisy chain my VCOs,
thanks!
reference: Connecting your sync generator to other modules
#2 — transistorcat · 2019-05-08
You can just connect the VC output to multiple cadets, it’s a parallel bus.
What you’re probably missing is a cable with multiple connectors, or a sync distribution backplane.
#3 — JunkRhythm · 2019-05-08
Here’s the Video Sync Distribution Cable that @transistorcat mentioned.
#4 — reverselandfill · 2019-05-08
I’ve made a sync busboard for that, see here:
[/forum/
#5 — visualex · 2019-05-08
thanks very much for your suggestions,
one question, what are the benefits of the sync busboard vs the sync cable? I just need to sync 2 OSC for now, but might need to sync one or two more down the road.
#6 — reverselandfill · 2019-05-08
The syncbusboard was designed for large systems with several modules that need sync,
the sync signals are buffered for better stability.
It features 10x sync out and also 1 or 2x RCA out.
Personally I like having a busboard instead of flying cables (which I find hard to DIY)
also, I like to minimise loose cables inside my case…
