Announcing the fifth Orion module, Fortress
#1 — creatorlars · 2018-08-02
We weren’t sure if we would be able to sneak Fortress into the initial set of Orion releases, but the design has matured quite nicely. We’re happy to welcome @pbalj onto the Orion development team on this one!
https://www.lzxindustries.net//shop/product/lzxoft-fortress-3046
#2 — Maytoast · 2018-08-02
Dammmmmmnnnnn! Orion is on some next level ish!
#4 — jkbh · 2018-11-06
Would i be able to use the fortress by itself with a Vidiot? or would i need a cadet sync / visual cortex
#5 — creatorlars · 2018-11-06
You will need sync, but you could sync from the Vidiot’s sync output. You’ll just need to pass the RCA cable to the rear of the Fortress module.
#6 — jkbh · 2018-11-06
Thanks a lot Lars!
I just found this thread, perhaps you could add fortress to the list of modules that require sync
