LZX Connect Guide
LZX Connect is the desktop companion app for LZX Industries instruments. It handles firmware updates and program library management over USB, without opening the instrument or handling SD cards.
Current support: Videomancer and Chromagnon (UF2 firmware updates). Chromagnon program library and settings backup require a future Connect release.
Installation
Download the latest release for your operating system from the LZX Connect page.
Windows
Run the .exe or .msi installer. No additional drivers are required. If Windows SmartScreen warns about an unsigned publisher, click More info → Run anyway.
macOS
Open the .dmg, drag LZX Connect to your Applications folder, and launch it. On first launch macOS will block it with a Gatekeeper dialog — go to System Settings → Privacy & Security and click Open Anyway.
Linux
Use the .deb package on Debian/Ubuntu-based systems (sudo dpkg -i lzx-connect_*.deb), or run the .AppImage directly after making it executable (chmod +x LZX-Connect*.AppImage). To use LZX Connect without sudo, add your user to the dialout group:
sudo usermod -aG dialout $USER
Log out and back in for the group change to take effect.
Connecting Chromagnon
  1. Power Chromagnon on.
  2. Connect the USB-C Device port to your computer with a data-capable USB-C cable.
  3. Open LZX Connect 1.3.8 or later. The Chromagnon device card shows the current firmware version and UF2 update controls.
Chromagnon firmware 0.1 does not expose program library or settings backup in Connect — use firmware update only.
Download releases from the Chromagnon status page or use Check for Updates in Connect (releases tagged chromagnon/).
Connecting Videomancer
  1. Power Videomancer on.
  2. Connect the USB-C Device port on Videomancer (not the Host port) to your computer using a USB-C data cable. Charge-only cables will not work.
  3. Open LZX Connect. The Videomancer device card appears showing the current firmware version.
LZX Connect requires Videomancer firmware 1.x.x or later. If your device is running firmware 0.1.8, use the manual BOOT button method to upgrade to 1.x.x first. LZX Connect cannot perform this initial upgrade.
Firmware Updates via LZX Connect
This method works for updates within the 1.x.x release series.
Pre-release firmware
Firmware 1.x.x is currently pre-release. If no updates appear after clicking Check for Updates, enable Show pre-releases in LZX Connect settings and check again.
  1. Open LZX Connect and connect Videomancer via USB-C.
  2. The device card shows the currently installed firmware version.
  3. Click Check for Updates. LZX Connect downloads and installs the latest available release.
  4. Videomancer reboots automatically when the update completes.
Firmware Update: Manual BOOT Button Method
Use this method when: - Upgrading from firmware 0.1.8 to 1.x.x (required — LZX Connect cannot do this) - LZX Connect is unavailable or not detecting the device - Recovering from a failed update
Caution
Close LZX Connect and any other software that opens serial ports before entering BOOT mode. Having LZX Connect open while the device is in BOOT mode can interrupt the process.
Requirements: USB-C data cable, Windows / macOS / Linux computer.
  1. Download the firmware .UF2 file from the Videomancer Downloads page.
  2. Connect Videomancer to its power supply and switch power to OFF.
  3. Connect the computer’s USB port to Videomancer’s USB-C Device port.
  4. Hold down the BOOT button on Videomancer.
  5. Switch Videomancer power to ON.
  6. Release the BOOT button.
  7. A USB storage device appears in the computer’s file system (shown as a Raspberry Pi — this is the RP2040 that manages Videomancer’s USB ports).
  8. Copy the .UF2 file to the detected drive.
  9. Videomancer reboots automatically into the new firmware.
Install Program Library
LZX Connect can install program library archives directly to Videomancer’s microSD card over USB.
Supported libraries: - Official LZX Program Library — available from the Videomancer Downloads page. - Community Programs Library — available from videomancer-community-programs releases. Signed releases load without Developer Mode on firmware 1.x.x.
Steps:
  1. Download the library archive (.zip or folder of .vmprog files) to your computer.
  2. Open LZX Connect and connect Videomancer via USB-C.
  3. Select Install Program Library in the Videomancer device card.
  4. Choose the library archive on your computer.
  5. LZX Connect copies the .vmprog files to the programs/ folder on the microSD card.
  6. Videomancer triggers a rescan and the new programs appear in the program selector on next boot.
If the microSD card is not present or not detected, LZX Connect will show an error. Insert the card and power cycle Videomancer before retrying.
Load VMPROG File (Development Sideload)
Load VMPROG File streams a single .vmprog directly to Videomancer’s RAM over USB. The program runs immediately without writing to the SD card. It does not persist across reboots — Videomancer returns to the previously selected program on power cycle.
This feature is intended for developers testing programs under active development.
  2. Select Load VMPROG File.
  3. Choose the .vmprog file on your computer.
  4. The program loads and runs immediately.
See the Videomancer SDK for tools to build and sign .vmprog files.
Troubleshooting
Device not detected - Use a USB-C data cable, not a charge-only cable. - Make sure Videomancer is powered on before opening LZX Connect. - On Windows, try running LZX Connect as Administrator. - On Linux, confirm your user is in the dialout group (see Installation). - Firmware 0.1.8 cannot connect to LZX Connect — upgrade to 1.x.x using the BOOT button method first.
Firmware update fails midway Do not disconnect power or USB during a firmware update. If an update fails, power cycle Videomancer and retry in LZX Connect. If the device enters a fault state, consult the Fault Codes Reference or use the BOOT button method to reinstall firmware.
Program library install stalls Power cycle Videomancer and retry. Ensure the microSD card is seated and formatted FAT32. As a fallback, copy .vmprog files directly to the programs/ folder on the SD card using a card reader.
