Reference Manual
Videomancer
Fault Codes Reference
When Videomancer encounters a fault, the LCD displays a hex code (e.g., 0x2C000008). Use this table to look up the meaning.
Hex Code Subsystem Description
Core — Messaging Infrastructure
0x00000001
Core
Null receiver ID passed
0x00000002
Core
Null ticket ID passed
0x00000003
Core
Null requester in ticket
0x00000004
Core
Duplicate receiver registry entry
0x00000005
Core
Receiver not found in registry
0x00000006
Core
Message receiver registry full
0x00000007
Core
Message queue empty
0x00000008
Core
Message queue full
0x00000009
Core
Invalid message packet
0x0000000A
Core
Re-entrant state transition
0x0000000B
Core
State transition guard failed
0x0000000C
Core
State machine rate-limited
0x0000000D
Core
Machine already suspended
0x0000000E
Core
Machine not started
0x0000000F
Core
Machine already started
0x00000010
Core
Sequence already completed
0x00000011
Core
Stack machine at max depth
0x00000012
Core
Stack machine has no frames
0x00000013
Core
Retry machine retries exhausted
0x00000014
Core
Queue machine full
0x00000015
Core
Queue machine empty on advance
0x00000016
Core
Machine already registered
0x00000017
Core
Machine not found in registry
0x00000018
Core
Machine registry full
0x00000019
Core
Machine not suspended
0x0000001A
Core
Pipeline has no data
0x0000001B
Core
Pipeline stage stalled
0x0000001C
Core
Request already pending
0x0000001D
Core
No request pending
0x0000001E
Core
Request timed out
0x0000001F
Core
Watchdog deadline expired
Silicon — System Clock
0x04000001
System Clock
Self-test failed
Silicon — Critical Section
0x04100001
Critical Section
Self-test failed
Silicon — Watchdog
0x04200001
Watchdog
Timeout exceeds hardware maximum
0x04200002
Watchdog
Self-test failed
Silicon — GPIO
0x04300001
GPIO
Invalid pin number
0x04300002
GPIO
Self-test failed
0x04300003
GPIO
Operation not applicable
0x04300004
GPIO
Bus communication error
Silicon — SPI
0x04400001
SPI
Invalid SPI mode
0x04400002
SPI
Null buffer pointer
0x04400003
SPI
Self-test failed
Silicon — I2C
0x04500001
I2C
Device NACK (no acknowledge)
0x04500002
I2C
Bus error
0x04500003
I2C
Null data pointer
0x04500004
I2C
Self-test failed
Silicon — Flash
0x04600001
Flash
Address alignment error
0x04600002
Flash
Address range error
0x04600003
Flash
Null data pointer
0x04600004
Flash
Erase failed
0x04600005
Flash
Program (write) failed
0x04600006
Flash
Self-test failed
Silicon — Resets
0x04700001
Resets
Self-test failed
Silicon — Multicore
0x04800001
Multicore
Null entry function pointer
0x04800002
Multicore
Inter-core FIFO timeout
0x04800003
Multicore
Self-test failed
Silicon — UART
0x04900001
UART
Null buffer pointer
0x04900002
UART
Self-test failed
Silicon — Unique ID
0x04A00001
Unique ID
Self-test failed
Silicon — USB CDC
0x04C00001
USB CDC
Self-test failed
0x04C00002
USB CDC
Device not initialized
Silicon — PWM
0x04D00001
PWM
Invalid slice number
0x04D00002
PWM
Invalid channel (must be A or B)
0x04D00003
PWM
Self-test failed
Silicon — ADC
0x04E00001
ADC
Invalid input channel
0x04E00002
ADC
Not initialized
0x04E00003
ADC
Invalid round-robin channel mask
0x04E00004
ADC
FIFO not enabled
0x04E00005
ADC
Self-test failed
0x04E00006
ADC
Silicon — IRQ
0x04F00001
IRQ
Invalid IRQ number
0x04F00002
IRQ
Handler conflict (already set)
0x04F00003
IRQ
No user IRQ slots free
0x04F00004
IRQ
IRQ already claimed
0x04F00005
IRQ
Self-test failed
Silicon — DMA
0x05000001
DMA
No DMA channel free
0x05000002
DMA
Invalid channel number
0x05000003
DMA
Channel busy
0x05000004
DMA
No DMA pacing timer free
0x05000005
DMA
Invalid timer number
0x05000006
DMA
Self-test failed
Silicon — Random
0x05200001
Random
Entropy source exhausted
0x05200002
Random
Not initialized
0x05200003
Random
Self-test failed
Silicon — RTC
0x05300001
RTC
Not running
0x05300002
RTC
Invalid date/time value
Silicon — PLL
0x05400001
PLL
Invalid VCO frequency
0x05400002
PLL
Invalid post-divider
0x05400003
PLL
No valid PLL configuration found
Silicon — Clock Tree
0x05500001
Clock Tree
Invalid frequency
0x05500002
Clock Tree
Configuration failed
Silicon — Voltage Regulator
0x05600001
Voltage Regulator
Invalid voltage level
0x05600002
Voltage Regulator
Self-test failed
Silicon — Crystal Oscillator
0x05700001
Crystal Oscillator
Init failed
0x05700002
Crystal Oscillator
Self-test failed
Silicon — Hardware Timer
0x05800001
Hardware Timer
Invalid alarm number
0x05800002
Hardware Timer
No alarms available
0x05800003
Hardware Timer
Alarm target time missed
0x05800004
Hardware Timer
Invalid parameter
Silicon — Cache
0x05900001
Cache
Invalid address range
0x05900002
Cache
Self-test failed
Board — Video Decoder (ADV7181C)
0x08100004
Video Decoder
Unsupported video timing
0x08100005
Video Decoder
Unsupported video connector
0x08100006
Video Decoder
Invalid chip revision
0x0810000A
Video Decoder
I2C communication error
0x08100032
Video Decoder
Self-test failed
Board — Video Encoder (ADV7393)
0x08200001
Video Encoder
0x08200002
Video Encoder
0x0820000A
Video Encoder
0x08200033
Video Encoder
Self-test failed
Board — HDMI Receiver (ADV7611)
0x08300007
HDMI Receiver
0x0830000A
HDMI Receiver
0x08300034
HDMI Receiver
Self-test failed
Board — HDMI Transmitter (ADV7513)
0x08400008
HDMI Transmitter
0x0840000A
HDMI Transmitter
0x08400035
HDMI Transmitter
Self-test failed
Board — LCD (ST7032)
0x08700036
LCD
Self-test failed
Board — ADC Capture
0x08A00001
ADC Capture
Not initialized
0x08A00002
ADC Capture
DMA channel claim failed
0x08A00003
ADC Capture
Already initialized
Kernel — Lifecycle
0x0C300001
Kernel Lifecycle
Invalid phase transition
0x0C300002
Kernel Lifecycle
Supervisor not registered
0x0C300003
Kernel Lifecycle
Message queue above capacity
Kernel — Capability Registry
0x0C400001
Capability Registry
Null capability pointer
0x0C400002
Capability Registry
Registry full
0x0C400003
Capability Registry
Duplicate capability
Timing Service
0x10000001
Timing
Timer not found
0x10000002
Timing
Timer already registered
0x10000003
Timing
Timer schedule full
0x10000004
Timing
Invalid duration
0x10000005
Timing
Invalid timer mode
0x10000006
Timing
Timer not paused (on resume)
0x10000007
Timing
Timer already paused
0x10000008
Timing
Message post failed
Logging Service
0x14000001
Logging
Sink array full
0x14000002
Logging
Invalid log level
0x14000003
Logging
Sink not found
Filesystem
0x1C000001
Filesystem
Generic error
0x1C000002
Filesystem
Drive not mounted
0x1C000003
Filesystem
File or folder not found
0x1C000004
Filesystem
No space left on drive
0x1C000005
Filesystem
File or folder already exists
0x1C000006
Filesystem
Invalid argument
0x1C000007
Filesystem
I/O error
0x1C000008
Filesystem
Too many open files
0x1C000009
Filesystem
Resource busy
0x1C00000A
Filesystem
Write-protected media
0x1C00000B
Filesystem
Invalid internal object
0x1C00000C
Filesystem
Invalid drive ID
0x1C00000D
Filesystem
No valid filesystem on media
0x1C00000E
Filesystem
I/O timeout
0x1C00000F
Filesystem
Invalid path or filename
0x1C000010
Filesystem
Path is a file, not a folder
0x1C000011
Filesystem
Path is a folder, not a file
0x1C000012
Filesystem
Folder not empty
0x1C000013
Filesystem
Bad file structure
0x1C000014
Filesystem
File too large
0x1C000015
Filesystem
Name too long
0x1C000016
Filesystem
Filesystem metadata corrupt
0x1C000017
Filesystem
SD card not detected
0x1C000018
Filesystem
Mount failed
0x1C000019
Filesystem
Unmount failed
0x1C00001A
Filesystem
Invalid file ID
0x1C00001B
Filesystem
File not open
0x1C00001C
Filesystem
Invalid folder ID
0x1C00001D
Filesystem
Driver registration table full
0x1C00001E
Filesystem
Invalid driver
0x1C00001F
Filesystem
Invalid mount prefix
0x1C000020
Filesystem
Media removed during operation
Settings
0x20000001
Settings
Preset not found
0x20000002
Settings
Storage full
0x20000003
Settings
Corrupt data
0x20000004
Settings
Setting not found
0x20000005
Settings
Settings working set full
0x20000006
Settings
I/O error during save/load
0x20000007
Settings
Setting already exists
0x20000008
Settings
Invalid preset name
0x20000009
Settings
Filesystem unavailable
0x2000000A
Settings
Serialization buffer overflow
0x2000000B
Settings
Value out of range
0x2000000C
Settings
Schema already exists
0x2000000D
Settings
Schema registry full
FPGA
0x2C000001
FPGA
Program not found
0x2C000002
FPGA
Program registry full
0x2C000003
FPGA
Invalid .vmprog package
0x2C000004
FPGA
Package hash mismatch
0x2C000005
FPGA
Package signature invalid
0x2C000006
FPGA
No matching bitstream variant
0x2C000007
FPGA
SPI transfer to FPGA failed
0x2C000008
FPGA
FPGA configuration timeout
0x2C000009
FPGA
Bitstream read failed
0x2C00000A
FPGA
Unknown parameter ID
0x2C00000B
FPGA
Parameter bridge write failed
0x2C00000C
FPGA
Parameter bridge full
0x2C00000D
FPGA
Invalid FPGA state for operation
0x2C00000E
FPGA
Service not initialized
0x2C00000F
FPGA
Filesystem error during program load
0x2C000010
FPGA
Configuration already in progress
0x2C000011
FPGA
Configuration not started
0x2C000012
FPGA
No DMA channel available
0x2C000013
FPGA
DMA transfer busy
0x2C000014
FPGA
DMA bridge init failed
0x2C000015
FPGA
Bitstream decompression failed
0x2C000016
FPGA
Video timing not supported by program
0x2C000017
FPGA
Crypto verification failed
0x2C000018
FPGA
Passthru program not found
0x2C00001A
FPGA
No programs in library
0x2C00001B
FPGA
All programs rejected (unsigned)
UI
0x30000001
UI
Invalid button index
0x30000002
UI
Invalid LED index
0x30000003
UI
Invalid toggle index
0x30000004
UI
Scan loop not running
0x30000005
UI
Service already running
0x30000006
UI
Pin not configured
0x30000014
UI
Potentiometer ADC read error
0x30000015
UI
Potentiometer value out of range
0x30000016
UI
Potentiometer signal too noisy
0x30000017
UI
Invalid potentiometer channel
Video
0x34000001
Video
Sync service not initialized
0x34000002
Video
Sync service already initialized
0x34000003
Video
GPIO IRQ registration failed
0x34000004
Video
Invalid sync pin config
0x34000009
Video
Analog decoder not configured
0x3400000A
Video
Analog encoder not configured
0x3400000B
Video
HDMI receiver not configured
0x3400000C
Video
HDMI transmitter not configured
0x3400000D
Video
0x3400000E
Video
Localization
0x38000001
Localization
Language not supported
0x38000002
Localization
String not found
Pseudorandom
0x3C000001
Pseudorandom
Stream pool exhausted
0x3C000002
Pseudorandom
Invalid stream ID
0x3C000003
Pseudorandom
Stream not allocated
Screen
0x40000001
Screen
Invalid screen index
0x40000002
Screen
LCD self-test failed
0x40000003
Screen
MIDI
0x44000001
MIDI
Unknown fault
0x44000002
MIDI
Receive buffer overflow
0x44000003
MIDI
Protocol parse error
0x44000004
MIDI
Invalid MIDI message
0x44000005
MIDI
UART port not ready
0x44000006
MIDI
UART hardware error
0x44000007
MIDI
MIDI-CI message malformed
0x44000008
MIDI
MIDI-CI MUID conflict
0x44000009
MIDI
MIDI-CI profile list full
0x4400000A
MIDI
MIDI-CI profile not found
0x4400000B
MIDI
MIDI-CI unsupported message type
Motion
0x4C000001
Motion
Invalid BPM value
Modulation
0x50000001
Modulation
Invalid modulator
0x50000002
Modulation
Invalid source
Shell
0x58000001
Shell
Unknown command
0x58000002
Shell
Command parse error
0x58000003
Shell
Required service unavailable
0x58000004
Shell
Input buffer overflow
0x58000005
Shell
USB CDC not connected
0x58000006
Shell
File not found
0x58000007
Shell
I/O error
0x58000008
Shell
SD card not mounted
0x58000009
Shell
Path too long
0x5800000A
Shell
Invalid path
Preset
0x5C000001
Preset
No FPGA program loaded
0x5C000002
Preset
Invalid preset index
0x5C000003
Preset
Preset slot empty
0x5C000004
Preset
Invalid preset name
0x5C000005
Preset
Save to flash failed
0x5C000006
Preset
All user preset slots full
0x5C000007
Preset
Save data malformed
USB
0x60000001
USB
Device not mounted
0x60000002
USB
Device buffer full
0x60000003
USB
Report generation error
